I feel like I should put an oak kit on my Tl-300. Is it really worth the money and effort? Thanks.
Now this thread is going oddly... where are all the Anti OAKlies?
Three stoves, no OAK, drafty house, no problems.
Hmm, maybe the three stoves are contributing to the draftiness?
I remember reading a single stove exhausts around 50 cfm from your home. Your 3 stoves running at the same time is like installing a 150 cfm fan in your window blowing cold air inside. Maybe some outside combustion air would help your situation?
No, the house is contributing to the draftiness. The doors are contributing to the draftiness. The windows are contributing to the draftiness. The poor insulation in the third section of the house is contributing to the draftiness. All of which do not have cheap solutions attached to them. Starting next year I will begin crossing some of it off the list, but it will be baby steps as each window will cost about $800 to replace and install.
To replace all windows and doors I am looking at about $20,000.
How are the stoves bringing in cold air when they are running?
50 cfm, interesting. That's 374 gal/min (6.8-55 gal drums) . Must be at max burn rate? Houses supposedly aveage 1-2 air changes/hour, ~400cuft/min for a 2000sqft home. One 130 cfm bath fan affects my draft without an OAK.Hmm, maybe the three stoves are contributing to the draftiness? I remember reading a single stove exhausts around 50 cfm from your home. Your 3 stoves running at the same time is like installing a 150 cfm fan in your window blowing cold air inside. Maybe some outside combustion air would help your situation?
When the stoves are burning the air they use for combustion is replaced from cold air coming through all those leaky doors and windows. Each stove is like a 50 cfm fan blowing warm room air up your stack, the negative pressure this creates pulls more outside cold air into the house to makeup for it.
How many of you have punched through 2 feet of masonry to put in an OAK?
