I am building a building in Idaho That is aprox 50' x 50' 2500 sq. ft.
Ceiling height if 14' flat.
This is a out building that will be used as storage and
studio / work shop. At one end it will be set up as a Man cave, probably a TV
pool table, couch that sort of thing.
The walls, ceiling, windows will be up to current standards, so it should be fairly
tight construction.
Average temps in winter, nights around 10 deg. days around 18 deg.
Its all open inside the building with no interior walls. just a 50 x 50 square box, but with fairly high flat ceiling.
I made the ceiling this high so if I ever wanted to store something tall like a motorhome
I could.
My question is do you think the king would be able to heat that open space to
a comfortable level.
Thanks
tight construction.
I could.
Thanks
