I was planning a DIY oak sometime this Fall and just wanted to get some input. Stove is in the basement, OAK would extend 8' up and another 8' to the basement wall. I was planning on cutting a 3" hole through the rim joist just above the sill plate. This would then extend through the sheathing. Now the only thing which may or may not be an issue is that it would exit about 4-5" below my deck - the ground (gravel / dirt) is about a foot below. The hole would also go through the deck ledger board.
Logistically, this is simplest method for my setup - any thoughts / safety concerns?
