Convection blower bearings
For a what?
Keep us updated on the bearing change. And how you do it.
Ok, got my convection blower off. To change the bearings I pulled the squirel cage off and took the fasco motor and blew the dust out. I marked a witness line on the case to get everything back in orientation, but the ends are tabbed so I dont think it matters much but you never know. Next I got a small screwdiver and popped the clips on the back. Carefull they my fly!! the bearings are held in each end of the motor with a rubber cup. The shaft has a small clip to keep the bearings out to the ends of the motor- no need to remove them. Put a bearing in each cup ,reassemble and tap the clips with a small hammer to replace them. I put it back in the stove and the WIFE says it quiter than when it was new! Hopefully it makes up for working on the kitchen table!
Reactions: mralias
The bearing are 8mm bore,22mm outer diameter, 7mm width witch is a 608 series. I got the electric motor quality,v2 witch is the vibration rating. Search the net and you will find tons of different styles. They even have ceramic bearing that size but I think they are for skateboards!
Too bad you didn't do a "How to" using pics of each step. I'm a visual learner....;)
We used to use ceramic bearings in the motors of high speed centrifuges. The ceramic bearings eliminate the problem of induced currents circulating through the bearings. That improved efficiency and improved bearing life. Those issues may not apply to ordinary AC motors, they were an issue for brush-less DC motors with their high frequency chopper drives.
I am always amazed of how much knowledge that exists on this forum.
