Hello
Most of the pellet stove manufacturers have told their control board makers to make one circuit board for all their different model stoves. It makes the boards easier for the service guy to have a board that will work and the board pricing is kept from escalating out of control. Also it is a good time for the board manufacturer to get those important mods, new chip algorythms and any important feature or change in that is on their secret SPR (System Problem Report) list as we called it in the softwre industry into the new control boards.
Therefore, knowing the older Enviro Max and Mini has some issues running on the lower heat settings, we popped in a new circuit board with new decal into a 6 year old Enviro Mini. Who knows what other good fixes are in there!
The new board has the Room Air Fan On/Off button on the board in the lower left but is not used in all models. Therefore, the program chosen for the model stove that does not require it, as in the case of the Mini just locks it out and the Mini Decal just covers it up. However the trick here is when programming the board for your model stove, you have to press thiis button along with the the Feed Rate Trim and Combustion Air trim simultaneously to program the board! LOL
So if you have the light gray decal and the 3 position manual, auto-on/off and auto-hi/low slide switch in the horizontal position above the other buttons you have the old board. The new board has a vertical (Up/Down) slide switch.
Enviro Model Programs from sheet in link below
Program 1: same as 3000 circuit
board parameter – for all pellet stoves
with the exception of units listed with
programs #2, 3, 4. – One flash
Program 2: Convection fan button
disabled – Empress FS – two flashes.
Program 3: 60,000 Btu feed rate –
Maxx – three flashes
Program 4: 50,000 Btu feed rate –
Maxx – four flashes
Note: To achieve 70,000 Btu, for Maxx
only, you need to trim up the feed rate
on program 3.
Has anyone else done this upgrade? Any comments?
See pics below.
Enviro part # 50-1929 - $329.95 from your friendly and knowledgable parts dealer
It works much better!
See Circuit Board Install Sheet in this PDF link.
http://www.enviro.com/newsletters/2009-11-08-Enviro Newsletter Summer 2009 low res.pdf
Maxx – four flashes
on program 3.
See pics below.
