I am a machinist by trade & on my BEST day, I couldn't fabricate everything this small, assemble it & make it run...
http://www.wimp.com/tiniestengine/
Quite a piece of work, but I was disappointed to see it only running on compressed air... not a diesel at all.
I knew it could not be diesel, no injectors. I was thinking RC engine fuel, that burns good in little engines like that. Spinning on compressed air, means the timing etc is not so critical. Yes it was a lot of work, but it is not a running engine. Big difference between spinning with compressed air and running.
JT, not sure if it would be splitting hairs but the old JD's ran on kerosene and used low compression with spark plugs. Not considered a diesel, so would those small engines you are describing be a diesel or just run on kerosene/ether mix which probably makes it capable of firing on low compression.
as for the OP the engine spins on compressed air, it is not running on fuel.
I did have some of those small Cox engines, .010 and .049, they were fun. We used to mount the engines with props backwards and make cars out of them, airboat on wheels. Had my share of cut fingers from props too.
