Yeah, I can, but it seems like there is a big swing in the feed settings. I have the unit direct vented straight out, draft all the way shut and the combustion trim all the way shut and I'm still over the recommended WC. So, on low the fire seems to be over powered...but if I trim up the feed it will keep going just fine. Problem being, I'd like not to have to set trim levels according to the desired heat settings. Oh, and I should mention, this is with soft pellets. I guess my biggest issue with the unit that I have is that it seems to require a lot of calibration from one pellet to the next. Another peeve, the control panel is dark and down low on the side of the unit, my wife often turns the blower off inadvertently while trying to lower the heat settings...and cause the thing really doesn't blow that hard to begin with, its hard to notice.
I suppose that's something somewhat unique to Enviro, they have so many units that are in production that run very much different from each other. Chances are, if you buy an Enviro unit you will get use to your specific stove and be none the less wiser and enjoy it very much...but as someone who plays with many all the time...the differences between each are somewhat highlighted in my use.
So here's the thing though, I LOVE the Empress freestanding. It uses the same control board as the mini, albeit a different program....ah...and you know what? I just thought of that
! I betcha my Mini is set on the wrong damn program. Don, whats the program for the Mini? I should know this, hopefully I'll remember to look later.
