Austroflamm Integra low limit switch location?
abaton6
44
Vermont
I think I have a bad low limit switch. The wiring diagrams do not provide it's location, so I can test it. Anyone know where it is? Thanx.
Ken in Vt.
Hi
I have the Rika Integra II insert. On mine, the switch is inside the Combustion Motor Housing near the exhaust exit .
page 10 /
Here is the diagram link via Lucky distributors.
http://www.luckydistributing.com/Heat/documents/IntegraFS.pdf
or the page where all the links can be had.
http://www.luckydistributing.com/Heat/product.cqs?prod_id=e3cd4a92c5bc16dcb6d01db92ea86deb
This is my 2nd year with he stove . Mostly a novice. A few others may chime in who have the Austroflamm Integra and are very knowledgeable.
Good Luck
Thanx pinetop. My old Ausrtoflamm is now ready for the cold Vermont winter, thanks to you. I found that a wire had come off the LTS while I had it all apart for cleaning. My bad.
abaton6
Happy I could help. This site is awesome for DIY er's Austroflamm /Rika information ( problem solving /tips etc ) pops up here occasionally . Some of the posters know these machines inside and out. Check back . !
Good Luck
Enjoy your Austroflamm! I just canabalized and old Integra insert that belongs to a friend in CO. He damaged it to the point that he replaced it and still had it sitting in his shed. I got the combustion blower, burn pot, ash pan and all the electronics. I am going to try to split the ash pan and make it so you can dump it on the run. We'll see how it goes. I have a couple of other ideas on how to make the stove easier to live with.
