Recently purchased a P68 (replaced a TL300 and Magnafire III)--looking to get something to power the stove when/if the power is out. Any ideas on the Harman battery backup device, or recommendations to crank up the stove if power is out...
Congrats on the new stove!
At the minimum, you need to have "True Sine Wave" output to your stove. (Inverters or generators)
I tried a cheap 12v to 115v inverter which was not a Pure Sine Wave. AC motors did not like it.
There are a lot of posts covering this subject. Do a search.
Here is a link to a Pure Sine Wave Converter. There are many out there. Should be some posts from
Folks who have them. I imagine there are some brands to stay away from. This is an example....
I have an APC with a pair of 90aH marine batteries wired in which gives me about 8 hours of runtime in a power failure. I also have a portable generator for longer outages.
I have alternative energy; solar array, battery bank, inverter and grid, plus a generator. If I was just starting out I would just get a good dependable generator. My choice is Honda, I bought the EU2000. It is an inverter generator so control boards and computers work, it is economical and portable. If I went with just a generator I would probably go a little larger. I am sure there are other good brands/models out there, just get a good one so that it will be ready when you need it.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
