I have cleaned my stove (insert) installed new bushings and Low limit switch, making note of wiring connections. Started stove up, auger came on, but no combustion fan, switched low limit connection around thinking this may be the problem (power unplugged), restarted, auger comes on but no combustion fan.
Pull stove out rechecking connections at terminal block, making sure connections are tight and nothing is pinched and I find a Blue and black wire (married) and not connected to terminal block, checking wiring diagram I do not see where this may connect and/or what they go to. there is only one spot on the top side of terminal block where it might go.
I do not have an ignitor nor thermostat.
Right side of diagram would be top of terminal block (I think)
Suggestions???
Suggestions???
