The manual said to check at a medium fire. I checked it about 18 inches of the top of the stove
Yeah Illinois burner did a load with the stove hot and shut the stove down to see if he could maintain a prolonged cat light off and decent stove top temps.. Something is wrong here, That dented chimney section is only an outside dent right?
The stove stalled out after 2 hours. Just had to turn it up a bit. The manometer tested at .03 positive. Now I have to figure out what that means. It's the high side of what I need I guess
The cat stalling on a lower burn is either due to the chimney not pulling enough or bad wood.(I can't see the cat being bad out of the box unless it didn't get a good wash coat). I can dial mine to 1 which is full closed and the cat will stay active for 24 hours.
I can't go to 1.5 without stall. In fact, I'm at 1.75 as a minimum setting. Illburner's cat is new so should be spunky.
Wood has been approved. Drafts checked out. There is something interactive that I'm not catching
For several weeks now you have been sucking a whole lot of flame through the cat,my guess would be that it is toast.Here is info from Firecat website.
Why is 'flame impingement' bad for the catalyst?
Direct flame contact is death to the catalyst. A catalyst burns the byproducts in the smoke. The gases such as CO, HC, and O2 ignite with each other in a chemical reaction in the presence of the catalyst (while passing through the honeycomb configuration). Direct flame inhibits this reaction by changing the chemical make-up of the catalyst breaking down the substrate or ceramic. Today's modern wood burning stoves are designed so that flame impingement is unlikely. However, it is not impossible. A strong fast draft can pull the flames into the catalyst. A hot fire with all the primary air controls wide open or perhaps the firebox door or ash pan door ajar are other ways the catalyst might receive flame impingement. Stacking too many logs in the firebox can elevate flames too close to the combustor.
I'm new on here. Not sure how to find Zanny. At 6:30 I was down to a few coals. Still just into active. About 240° on stove top. I would have to borrow my buddies bucket truck again. Here's pics of the outside.
Your draft, while checked, is weak. As the outdoor temp drops, the draft should increase. .04 is almost a minimum.Wood has been approved. Drafts checked out. There is something interactive that I'm not catching
Illinois. Ridiculous you say living in a mobile home and have 12' of stack out on the roof. People tell me they can see the stack before the trailer . It works that's all that important to me . I still have some tweeking to do before I'm happy.I put another 4 feet of pipe on today giving me at total of 19 feet outside. It looks ridiculous. I just loaded it with the wood I have at 3:45. The next load will be the kiln dried wood. Hopefully I see a dramatic change
I'm not enclosing it. I may at a much later date, when funds are better, run it through the roof.
Those pictures are when he was loading and early in the burn. When the wood is fully engulfed it appears the bypass is closed.
I was looking at the pics you posted on page three of the stove and on the pics showing your stove the bypass lever was open on both pics, "when the lever points to you its opened, when its pointed away from you its in the closed position" I know those were pics of the stove before and after a reload but can you confirm that the lever is pointed away from you right now?
