Question for Mike at Englander or others with an Englander
SJohndro
19
Hi all,
I am getting ready to replace the door gasket on my englander 25-PDVC. I was wondering if there were directions available for this. I haven't been able to find anything on the englander webpage. Perhaps someone can point me in the right direction.
Thanks!
Not much help but did check the owners manual
This unit comes with a 3/4” rope gasket around the door that should be replaced at least every two years. To replace the door gasket (Part # AC-DGKC), the old gasket must first be removed entirely — prior to adding the new adhesive, you may have to scrape the old cement from the door channel. Once the cement and gasket have been added, the door should be closed and latched for twenty-four hours to allow the cement to harden
My 25 PDVC shipped with a DVD in which Mike demonstrates the essentials of operation and maintenance, including the replacement of all gaskets. If you cannot locate your copy, it is available from ESW for the cost of shipping and handling ($12.50 via UPS).
