Destructor
Burning Hunk
If you like an open fire and can afford the cost go for a fireplace and a stove. One for efficient heat the other for fun and some heat. If you like gathering and processing wood who cares if a fireplace is inefficient. People burn outside fire pits all the time. A properly built fireplace will warm the room it is in. The stove will warm the house.
Don't even think of using a mason who won't build a proper footing. Also make certain that the mason uses steel in the hearth. It spans the ash pit and the outer hearth cantilevers out around 18".
