do you tink it is worth the 60 bucks and what percent of the time do you fell it comes into play?kevin j said:I used one with the rigid foot under it. Nice for bucking small stuff but it has to be totally round. Any branches or forks, it didn't work. It has to roll the log as it picks up, and if any branches prevent that, it didn't work.
So I added a pivoting foot to my cant hook and it works great. Light angle on each side, downto a flat plate. pivots on a pin through the handle. allows the leg to stay in one place while the log rolls a bit.
Not intended to be a holder for cutting, as it doesn't go 'over center' and hold it up. Use is to lift a log and allow putting some blocking under it.
kcj
mayhem said:Bought one this spring, works great. About $35 at Tractor Supply...took them abuot an hour to even figure out what I was asking for but then once they found ne I got it a couple days later.
I do use mine to lift the log and cut, it holds anything from about 4" up to around 12-13" in diameter. Anything bigger and it just doesn't bite the log. Nice also that you can remove the jack with a box wrench and viola!, instant cant hook.
All steel and nice and heavy. The jack is a 8-10" inverted T so its nice and stable when jacking.
Well worth the money.
Shipper50 said:I bought one from Northern tools and its the metal one like a pipe for a handle. I bent it the first time I used it to move a log of around 22 inches and don't like the point it comes with as it slips out of the wood.
I would buy a wooden handle one if I was going to buy one again and make sure the point that hooks into the wood is sharp so it doesn't pull out when one puts pressure on the handle.
Shipper
great review been looking at them for a couple of months now,will pull the trigger(the peavy is the one i have been looking at)Jags said:Yep, its always with me when I am cutting.
Uses:
1.)unbinding a saw blade when stuck in a cut
2.) rolling logs
3.) when felling, I have used it to twist a tree in a specific direction (not recommended for casual cutters)
4.) picking logs off of ground to be cut.
5.) when bucking large rounds, I use it to move the last round I cut, to get it out of the way (if they won't roll easily).
Handy tool. I have the wood handle version and if it broke or was lost, I would replace it very soon.
smokinj said:great review been looking at them for a couple of months now,will pull the trigger(the peavy is the one i have been looking at)Jags said:Yep, its always with me when I am cutting.
Uses:
2.) rolling logs
the peavy iam looking has that they are 60.00 bucks and the quick pina great ideaJags said:smokinj said:great review been looking at them for a couple of months now,will pull the trigger(the peavy is the one i have been looking at)Jags said:Yep, its always with me when I am cutting.
Uses:
2.) rolling logs
Food for thought: the timberjack has an inverted "T" leg that allows for lifting that the peavy does not. The leg is removable with a wrench when new. If the bolt is replaced with a 3/8" pin (I think that is the size) and a hair pin, it can be made so that the leg can be taken off or put back on in about 3 seconds. Best of both worlds. Timberjack one minute, peavy the next.
i dont see the jack parttimber said:yes but thes guys http://www.logrite.com/index.html make the best cant hooks, log peaveys, timber carriers, hookaroons and logging arches they have aluminum handled tools are stronger, lighter and safer to use than the traditional wood handle models. We engineered our tools to work better and not to break under normal usage. Our tools are designed to increase employee safety, reduce downtime and liability
