Enviro Pellet Stove Trouble!!!
Oh great, i managed to find this site and read the forums AFTER i've put a deposit on a Maxx.
Anyone know if these 'bugs' have been fixed??
The stove works better then it did when first installed but the burn pot will stilll clink up and need to be manually emptied before it will restart. The company is coming to install a larger blower which will keep the ash from clogging the pot. The reason why I bought the stove was to add the thermostat kit to it so I could have it regulate the heat more efficiently which would require the stove to relight on its own which it cannot do at this time.
I would like to think the stove you just purchased would have the upgrades complete already which included improved door gasket, burn pot spacers, upgraded burn pot and the blower.
The Stove itself gives off a lot of heat, wish you could regulate the blower more but that would be the only fault I would give the stove other then the larger issue I am having which is more of a defect in a first year model.
It would not hurt to talk to your rep and see if they have installed one before and ask to speak with that customer.
x96mnn said:
Up stairs I installed EF3Bi with nickel trim door kit...heats up to 2000sq ft so heating the top floor which is 1120 is no problem. Stove works very well and on the level I run it can get a little over 2 complete days from a bag.
Over 2 days from one bag? That`s got to be phenomenal !
I agree...2 days from 1bag would be amazing, but I'm wondering if he meant "from 1 FILL" of the hopper?
My interest in the 2 days+ from one bag claim is that my little Harman P38 gets only 36 hrs from a bag on the very lowest setting and from what I can gather my stove is burning cleanly and appears to be operating perfectly.
According to the brochure it should burn only .75lb @ the #1 setting. That would put it at 54 hrs .However I wrote that off to hyped up advertising and or tests from optimum conditions that are simply difficult to match under field installed situations.
Certainly I would not want to refute the OP`s claim since it could very well be possible that his stove somehow matches or comes close to the exact criteria to get the optimum low burn rate . This is something that probably few of us can lay claim to.
After even more thought on this I can conclude from my lowest burn rate @1.1 lbs per hr (36 hrs per bag) experience that if I could somehow attain a low burn rate of just .75 lbs per hr it would produce very very little usable heat to my room and would be operating at a severely reduced efficiency . Most of that heat would be going right up and out the the flue. I just can`t see how .75 lbs of pellets burning for an hour can produce enough heat to a room with any degree of efficiency.
The hopper to me appears to be full, no expert in Pellet stoves but am using a 40IB bag of Shaw wood pellets (produced in the Maritimes)
I would fill the hopper Sunday between 8 and 10am and the stove would burn Sunday, Monday and run out while I was at work Tuesday if I would forget to top it up Tuesday morning.
As for throwing heat it does just fine although it may be my perception only with the enviro max doing the blunt of the work keeping the floors warm down stairs.
Thats 2 days + on a 40lb bag and doing fine regarding heat.
That`s got to be amazing. Congratulations! You are doing what most of us only dream of.
I bought a enviromax this summer and so far no burning problems . My problem is that the pellets keep hanging up in the hopper .
I have 10' of 3" chimney at 45 degrees and 15 ' straight up with a outside 3" draft intake . Just adjusted draft until glass stays clear and good flame .
I have burned 16 bags of pellets with no clinkers and I am burning premium low ash pellets . The pellets are stored in a dry place and do not seem to have a dampness problem. I am very happy with the heat that comes from this stove .
It is just that I have to go and shove a stick to loosen the pellets every few hours or else the stove will go out and that is frustrating .
During writing this letter I just received a call from my dealer and she told me to pull out the grate in the bottom of the hopper .
I will try this and get back to the forum in a few days with the results .
Bill
Update
They have replaced the fan and the stove now works perfectly, can go days with no issues!
Although it took some time I am very pleased with the heat and performance of the enviro Max.
Does your stove have the 3" or the 4" vent.
Not sure what you mean my vent, own two stoves, can turn them on and off and clean them but any more ten that I am lost.
Sorry' I meant the exhaust vent. I believe last year The Maxx started coming with 4" exhaust.
hearthtools said:
x96mnn said:
Repairs were made to the stove today, (yes it took too long), and I am sad to report it did not resolve the problem entirely! Made it definitely better but there is no way this stove will be capable of being hooked up to a thermostat and shut down and relight without the burn pot being cleaned out.
I started the burn around 11:00 today and when I came home around 7:00 the pot was about half full in the middle and clear around the sides which I thought not bad, it�s still burning and not over flowing with the side bottoms being seen. Impressed to this point I tried a shutdown which to my dismay at the end the pot in the middle has about a half inch of what looks to be well burnt pellets.
What next? Not what I expect from a $2000 machine!
You got a good deal at 2K
the list price $2200
Plus around $398 for large glass door
or $300 for small glass door
Most standard pellet stove are over 2K
the Omega list price is $4200
