jtakeman said:StoveMiser said:Hope that harman has a big hopper to support 8 pounds per hour. At 4 pounds per hour my big e gobbles pellets faster than I prefer, but with todays pellet prices it sounds like a costly venture to dump a bag in every 5 hours. The room that the stove is in must get disturbingly hot...
Where'd you get 8 lbs per hour from a Harmon?
Last I knew they were at 5 on max! The Enviro Omega and Maxx are the only stoves I know that will consume 8 LBS/HR.
jay
http://www.harmanstoves.com/specifications.asp?id=1
Even our Accentra can burn more pellets than we want to buy. The dealer we bought from did not belittle other brands. He had a Harman XXV, and a Winslow in his home. He said both were good pellet stoves. He did say the XXV will run with less attention, and can put out much less heat on low burn, and more heat on high burn than the Winslow.
The difference between how much heat you get from different pellet stoves will depend mainly on how well the heat exchanger works, and how much fuel you burn. When I see claimed efficiency ratings of 80% or more, I am a little sceptical. Under ideal test conditions, maybe.
