Strange smell...question.
Swedishchef
3,275
Inuvik, Northwest Territories
Hey Guys
Lately (past month and a half) I have noticed a strange smell upon lighting my wood stove. It is coming from my double wall stove pipes. It is actually coming from the small vents in the outside layer of the double wall pipes. It smells sweet. Once the fire gets going, after about 45 mins and everything is nice, hot and rolling, the smell is gone. I am trying to keep the stove going 24/7 since my wife is pregnant and can't stand that smell. Any ideas? Would this be the smell of creosote?
I have already tried heating my pipes numerous times to temperatures of 800-1000 degrees and the smell is still there.
I gotta get this smell fixed, it's gonna drive her (and then me) nuts.
Andrew
Bumping to the top . . . this one deserves an answer . . . unfortunately I am not the one to answer this as I am a bit perplexed.
If this was a new install I might suggest it is the smell of paint curing . . . but it seems as though this is not a new install and most folks don't describe the smell of curing paint as "sweet."
Creosote is also not generally described as "sweet" as most folks tend to describe the smell as being bitter, chemical-like, etc.
If I had to guess I would say it almost sounds like smoke from some type of "sweet" tree (i.e. softwood, cherry, apple, etc.) which could possibly be caused by a less than ideal draft (perhaps due to a partially blocked chimney) . . . once the draft is going and going well there may be enough of a draft to remove the smell. The only proverbial fly in the ointment is that I would think you probably know what smoke smells like.
In any case, perhaps others will chime in with some ideas . . . if nothing else it may be a good idea to check and clean your chimney if you haven't done so.
I know when my flue gets too hot by the smell. I know when my stove is puffing by the smell. They're both different. Neither is sweet though. And the flue odor is temp. related which can happen at startup only if I run too hot.
Could be something to do with poor drafting on startup for you?
By chance did the stovepipe ever leak?
Thanks for the replies guys.
I don't have an Fn clue what it is..I assume it is creosote. My nose isn't perfect..so perhaps it is a bitter smell. I dunno. However I know it is not paint curing. I fired up my stove hot quite a few times and saw smoke coming off of the stove pipe and stove. My basement was full of it..the wife loved that one!
It is not the wood, I am not burning cherry. Only yellow birch (beech), some softwood and some maple now and again. I mostly smell it on light up but once the stove is hot, it's gone.
It could be a bad draft...My chimey is outside of my house. I do not believe there's a leak in my pipe. But I no longer have any smoke rolling from my stove after the initial lighting...I get a good updraft going. I have only had 3 cases of negative pressure..a window open for a bit fixed that.
Since it's going down to -25 C in the next couple of nights, I am not gonna stop burning right now, I will stop at the end of the week. I don't think it's a fire hazard but I do want to take my pipes apart and get everything looked at.
It's strange......to be continued!
You said it happens at start up. What are you starting your fires with. This is my first year burning and I grabbed a box of Fatwood to try. It gives off a weird sweet odor.
If possible, I'd get up on the roof, and smell the cap! That way you'll know what creosote smells like and will be able to tell if that's what's coming into the house.
I'm amazed that this smell is only coming out when the stove is cool and warming up.
I am perplexed too!
pen
Thanks for the kind replies folks.
I am lighting my fires with softwood and hardwood kindling.
Honnestly, if it's not creosote that I smell, I am taking back all my stove pipes! The smell on light up is tiresome. It fills my entire house. It is not a leak, it's not smoke. Like I mentioned, I can smell it through the vents that are located on the outside layer of my stove pipes.
I don't wanna get on my roof right now. I would need a step to be able to reach my chimey cap. My roof has a foot of snow on it and it's a decent pitch.
In the words of Charlie Brown: ARRRRRRGHHHHHHHHHH
Gonna call my installer. He is certified and he also sweeps so I want him to come to look at it. I will have to let my fire go out and start from a cold start.
Andrew
Hi,
I have the exact same smell with my chimney- for 7 yrs now. Mine smells a little waxy as well as sweet. I have the same slotted double-walled blk pipe.
Do you by chance have selkirk chimney? The end of my chimney is missing the smoke pipe adapter- thus exposing the creepy plastic that holds the insulation in place- pre installation. I am telling you all this because I have always attributed the smell to that plastic as I have watched it melt over the years....
Hey
No, I do not have a selkirk chimney. I have a Security Chimney.
I can't see it being plastic, otherwise, would it not simply burn off and go away after a while?
In all honnesty, I don't have a clue of my setup. A guy installed it for me while I was at work. He was highly recommended in my area by numerous people, is very honnest and kind. He builds mason fireplaces, does all kinds of installations, etc. Fully certified. Works even weekends if need be!!
All that to say, I don't think it's a plastic smell. It seems as though the smell is coming from the pipe itself. The pipe that smells the most is the first one that raises from the stove upward before the first 45 degree bend.
Andrew
Bugs crawled in the slots in the off season?
There was no off season: my setup was installed on november 14th.
I have been using it since. Initially, I would only make a fire when I got home from work. But this past week it's been going 24/7.
I tried calling my installer last night and there was no answer. I will try again tonight, tomorrow night, etc etc.
Andrew
I had the same problem. The only similar aroma I can think of is burning sugar in the oven. I wrapped every stove pipe connection with fiberglass gasket and clamped the gasket in place with steel strapping, just wanted to be sure it was not a leaking stove pipe- No luck there! The problem was the fiberglass gaskets in the Harmon Oakwood cast iron stove, they failed and the stove was only a year old. I returned the stove and exchanged it for a steel stove made in BC. If you have a cast iron stove you may want to look at a few gaskets, I was shocked when I did, gaskets in the bottom of the stove were burned and leaking. It was very difficult to determine where the smell originated due to the rising heat effect.
On the first Freedom Bay insert in late December of 2008, that sweet smell started just a few months after being installed. It is almost overpowering and you wonder how much of it is trapped in your clothes you wear to work or to town... It always started at the end of a low/slow burn, when fire was down to just red glowing coals. With a lower heat, I'm guess there was also a LOWER draft, and when really low temps. hit, the heavy cold air slowed whatever draft was there was....
That unit is being shipped back to Travis Industries for them to findout if there was a leaking fractured weld. If there was an air leak from a crack, then it allowed air in. My guess is that if they find a broken weld/crack, the added inlet of air allowed a sloppy sealed door to "leak" out the sweet smell, instead of it going up the flue.
Even before it being pulled out a few weeks ago, what stopped that sweet smell was the change-out of the cast iron door frame. With a new door and its new seal, the sweet smell had stopped, but the First Alert fire & CO detector kept picking up spirts of high Carbon Monoxide... I guess the be best encouragement the OP might take to heart is to be sure he has a CO detector...just in case there's more than smell getting back into his home. Checking the door seal by placing a dollar bill between the seal and the fully clamped/closed door by pulling it out and feeling the resistance. On the first door, the leak appeared to be at the top right...
Bill
Hey
Well, it's nice to know that I am not the only one who has had this problem. It is quite perplexing. I will have to look closely at the setup. Then again, I will call my installer/distributer and ensure that he fixes it..his work is on warranty for 1 year and the stove is lifetime (pfft).
Thanks for the comments guy. I will keep heating this week (the temperature just dropped 7 degrees C in 2 hours! Brr) and once it warms up a bit I will get him to come clean my chimney and look at my stove with me
Andrew
Swedishchef said:
Hey
Andrew
I just remembered what that smell was like and where I've smelled it before.... That sweet-tangy odor is like a molasses block you feed to cattle...like you'd buy in a commerical feed store.... Maybe this will help others to know... ;>)
Bill
Hmmm . . . very odd. Let us know what you guys find out . . .
I don't think there's anything getting particularly hot...
Also, I noticed that when I place a bar b q lighter that is lit in front of the slots that are in the outside wall of my stove pipe, there's enough wind to put it out. Does that make sense?!
Andrew
I'll take a stab--
How do you know the smell is coming off the pipe? If it only happens at startup, what if your flue reverses when cold, and you get a burst of cresosote-smelling air in the room while you are loading up? It has then dissipated by the time the stove is rolling.
If you have localized the smell to vents in the pipe, well, if the flue is reversed, the pipe's air gap is also flooded with the same smell, but the stove loading could be when the big dose gets released.
Try sweeping? Try some of the anti-sote powders to dry out whats in the pipe?
Oh yeah....do you know your pipe is installed properly/right side up? Maybe some creasote leaked into the air gap due to improper installation, and now your cooking that smell off, until the draft is strong enough to pull in on the pipe vents.
You are using and have a CO detector ?
Hey
I can tell the smell is coming from there because I stick my nose right in it upon light up. I don't see how it could be from the flue unless the installation was not done properly. Yet the guy who installed it is highly recommended and does it full time (6 days a week). He seemed to know what he was doing. He installs about 50 chimneys a year and is also a volunteer firefighter and has been for 15 years (not that it makes much of a difference). I am just trying to convince myself it is a proper installation.
When lighting, I don't often have a downdraft. I have had maybe 5-6 in almost 3 months. So I would expect that upon light up, the smell SHOULD go right out the chimney, if it is coming from there, no? Maybe I should invest in one of those anti downdraft chimney caps.
I checked the stickers on the pipe. it is right side up.
Something tells me it could just be the pipe of a faulty installation. Either way, I want it fixed. Because now I am looking my cool. My wife doesn't want me starting it up since she's pregnant and hyper sensitive to smells at the moment...good thing they are calling for mild weather this week.
I do not have CO detector yet (unfortunately). I will buy one this week. CO has NO smell, this is a sweet smell that eventually goes away. If I stick my nose into those vents I can smell a bit of burnt smell
Andrew
My wife isn't pregnant but she has an olfactory like a bloodhound. Just the tiny bit of creosote smell coming off the end of the poker is enough to set her off. Opening the stove door into the room can release some smell off the inside surface into the room too if it hasn't yet burned off. I made the mistake of putting some stove polish over some rusty spots and incurred her wrath. Had to let the fire go out last night to maintain marital harmony.
Metal will give off smells particularly when combined with other elements. Just try handing some unprotected metal and then smell your hands.
