Well, at long last my Jotul 550 insert will be.... inserted this week. I made sure to specify to the installer that the stainless steel liner must be wrapped in insulation, since it's an exterior masonry chimney about 26' tall. He talked me out of a block-off plate at the damper level, because he said it's going to be pretty tight in there already, and he will be sure to insulate it well. I hope he's right.
Also, I will make sure that he uses the leveler bolt in the back of the firebox (which I saw in the installation manual, online) , since the floor of my fireplace seems to pitch down towards the front of the hearth.
I'm also asking that he stuffs insulation the ash dump at the bottom on the fireplace -- should I also put a piece of slate on top of the hole?. Just seems weird having an open hole there beneath the firebox, no?
Any other words from wisdom from those in the know? Once the 550 pound behemoth is in place, I don't plan on moving it. So now's the time to find out. Thank you!
