Sen. John Blutarsky said:Remember that you are coming off of an abnormally cold winter for you folks. Something around a 1.5 -2 cu/ft firebox would probably do just fine. How is your insulation?
Out of a rating of poor, fair, good, excellent, I would give it a rating of good.. There is extra insulation in the attic... I am going to take the vinyl siding off and add osb w/ radiant foil barrier (I have the radiant foil) and at the same time install the new windows I have already purchased. Then at that point, I can give it a rating of excellent... .. Next step Solar.....
