Show me your tools...
nailed_nailer said:
So I stopped into Lowe's tonight on the way home from work.
I had to pick up something to cut some 1/2" and 5/8" circles in cowhide.
While I was eyeballing plumbing fittings and pipe I noticed some 1/2" OD with 3/8" ID polyethylene tubing
It was $.27 / foot so I bought just over 6' of it.
So If you guys would like a vac adapter tube I can make about a 1/2 dozen or so.
Get me your vacuum hose inside diameter and a mailing address and I will send you one.
---Nailer---
Nailer,
An adapter like yours is what I have been searching for.
What a kind offer.
PM has been sent.
Thanks very much,
Ranger
Here's mine.....putty knife for the burn pot scrape once a day, and for my weekly cleaning I have a chisel and a flat screwdriver to get any built up creosote off the end of the auger tube and around the burn pot area, my 6 gallon shop vac, a short piece of garden hose (wif a little tape on one end so it fits snug in the end of the shop vac hose) to get into those hard to reach spots, and a flashlight to help me see into the nooks and crannies ;-)
What are some of you guy's doing with the hammers? I like my stove, had some problems here and there, but not once have I thought about beating it with a hammer. Settle down fella's there are guy's here that can get you through about anything. :)
Maybe to tap the chisel with, some folks have been known to pound on baffles to knock loose ash down, etc .... I also like my stove and no hammers get used.
Impressive! What's the handheld scanner looking thingie at the lower left??
smwilliamson said:
Those are called paper towels.
Bahahahahah! Oh, that so funny to me.
:roll:
I would have thought with all of these tools, there'd be nothing left for the paper towels :)
Missing from the pic is the drywall vac and mini hose home made attachment.
Oh and I use the hammer to gently tap all over the inner/back wall of the stove
which releases more crap that falls into the ash traps and then proceed
to vac it out with the mini attachment.
Nice. I guess that works better than licking your finger and listening for the sizzle :)
Why waste time licking your finger when you can just put your tongue on the stove. :p
I don't have a pic, but my entire cleaning kit consists of a 2.5 gal. shopvac, the scraping tool that came with the stove and a roll of paper towels. What the heck am I missing here? :-/ (besides the hammer)
Hello
A Lowe's Halogen lamp makes a great Pellet Stove Cleaning Light.
Also Home Depot's ceramic CookTop Cleaner is way cheaper than the Stove Shop's Glass Cleaner!
The ash dump brush came with the stove.
Of course I use a 6 gallon Rigid shop vac for the dusty ash. :)
  • Show me your tools...
Awesome thread, thanks to all who took the time to show the tools and offer their tips.
Time to make one of those vacuum attachments, great idea that I would have never though of.
smwilliamson said:
ok here's mine:
Wow, for a pellet stove! Kind of looks similar to what we would set up on an instrument table in an operating room! I trust your "clients" are cured.
save$ said:
smwilliamson said:
ok here's mine:
There is a tool I use everyday which got blocked behind the cleaning box, you can see the red handle. it's an oil filter wrench...the BEST for disconnecting the clean out cap on T's and taking very stubborn pipes apart. A must have.
kofkorn, can you install stove boards on the sides? I think that would take care of your clearance to combustibles? But I still would not want to be the one that has to service the unit!
I've considered that, and I agree with your comment on the service, but even worse would be the ability to access the control board. If you look at the second picture on the right hand side of the stove, I used a couple of angle brackets to face the control board forward. If I reduce the clearances even a little bit more, I won't be able to reach the control board.
Nope, I think it's going to have to be the hard way.
I noticed that the ONE thing I haven't seen yet, in anyone's photos, is a basic "ABC" Fire Extinquisher. (No, I don't normally keep it right NEXT to the wood stove. I put it there for this picture, just to illustrate the basic tools I need. A good pair of gloves, the poker set, and the Fire Extinquisher).
-Soupy1957
Hello
New tool thanks to Nailer. :)
Ash Trap Cleaner for Shop Vac in cherry hardwood!
shop vac, paint brush, scraper and 1 child.
Don2222 said:
Hello
Me too!! Great job on the adapter Nailer...Thanks again!! :)
I recieved my cherry adapter also.
Nailed_Nailer Nailed it and then Mailed it!!
Perfect fit.
Coating it with polyurethane before use.
Wife wants to borrow to clean the baseboard heat units.
There ARE some really NICE members of this site.
Thanks Nailer.
Ranger
