Hello Everyone,
This is by far the best forum on the internet! And you great folks make it that way, THANK YOU!
I found a new Lopi Declaration for $2500 out the door dollars but am concerned about it being too much stove for my well sealed and insulated rancher in east TN. I am currently heating with a 1980's small buck insert(1.6 cu/ft firebox) and it does a good job heating the whole house but overnight burns are non existent and the stove is 20-30% less efficient compared to the new stoves. I want to upgrade so we can enjoy the flames through a clean glass, do less chimney sweeping and save some firewood in the process.
I have a SST lined masonry fireplace in the great room(12' cathedral ceiling) located on the north end with all the bedrooms located on the south end. Just finished installing a 20 x 25 return air filter/grill and 16" R27 flex duct in the peak of the cathedral ceiling to move all the hot air through the duck work system and balance out the temperatures from one end of the house to the other. Temp delta is now 3-4 degrees so I'm happy with the heat distribution even though it was a lot of work.
My greatest concern is having a 2.9 cu. ft. firebox and having to burn a hot fire to get the secondaries to kick in but overheating the house in process. Is the Declaration going to be too much stove?
All replies are greatly appreciated.
