Powerlog?
Jimbob
Driving home from work the other day, I noticed a sign for these in front of a wood stove store.
http://thepowerlog.com/
I don't need any, I have lots of firewwod, I was just curious about them.
Anyone try them?
Grab a batch and try them out. I sure would if they were close by.
One of the leadership members of this forum should go here and contact them for a free sample. I think they will be happy to send it
http://thepowerlog.com/power-log-promotions.asp
I went through the site and cannot find anything about how many BTUs or how hot it will make the stove. What good is a 15 hour fire if its only 250 degrees?
It only says it has more BTU's per pound than oak cordwood.... the question is how much more?
Right
If it has very little more BTUs than oak... but burns over a 15 hour period, then you will be getting less heat per hour from these things and in the colder climates that might not work out for you
DonNC said:
Right
I just talked to a rep and he stated that it had 8,644 btu per lb...what is oak per pound?
DWBMHD said:
DonNC said:
Right
Oak is 8600 BTU per pound.
http://www.woodheat.org/index.php?option=com_content&view=article&id=91&Itemid=109
Scroll ~ 2/3 down.
Jimbob said:
DWBMHD said:
DonNC said:
Right
Scroll ~ 2/3 down.
Why the discrepancy between the 2 sites?
DWBMHD said:
Jimbob said:
DWBMHD said:
DonNC said:
Right
Scroll ~ 2/3 down.
Ya that 44 btu discrepancy could really through a guy off and cause him to freeze this winter. :lol:
I am actually talking about the discrepancy between the 6388 and the 8600 numbers...between the 2 sites... and thats 2212, kind of a big discrepancy there
Sorry, only used the #s in your quote. :red:
Ive only burned pine, poplar and spruce and the #s for them are much lower than the 2000 difference and it still does just fine.
Interesting concept...but i'm not a believer in the 15 hour burn,,,,it might burn,,,but how much useable heat would ya get? Might be good for a fireplace, just cant see it workin that good in a wood stove. Anyone locate pricing on these????
Maybe red oak vs. another type of oak?
Bascially what woodheat.org says is that ALL species have the same BTU per weight, But because some wood is heavier than others, the heat per cord is different.
I've heard in Austrailia, they sell wood by the TONNE, so that no matter which species you buy, you are paying for a certian amount of heat.
A couple problems with that, first, wood sellers would need a scale big enough to weigh that, and some people would be selling green wood, because it's heavier.
Inquiry sent.
DWBMHD said:
DonNC said:
Right
Never burned flax before, but here are some comparisons:
HomeFire's Prest-Logs: BTUs: 8730 btus/lb. Each log is 5 lbs or 43,650 btus
Northern Idaho Energy Logs: BTUs: 8,600 btus/lb. Each log is 8 lbs or 68,800 btus
BioBricks: BTUs: estimated 8,500 btus/lb. Each brick is 2 lbs or 17,000 btus
Anyone try them?
Which stove shop in the city, I might pick one up to use in the fireplace when Spring finally arrives, just to try out the product. They seem to be manufactured in Brandon which makes sense considering its an agricultural area. Txs
yeah- I burn a mix as well and don't necessarily care about my usable BTU's-:) I've got 3 spruce trees in my front yard that I can't wait to take down, process and burn!
I just find it interesting the science behind the BTU math and am surprised about the differences...
Understood. ;-)
