Todd said:Punched a hole in the bottom of the chimney to help remove the tile, he said it is easier than using the small cleanout inside and making a mess in the house.
leeave96 said:Todd,
I see the square/rectangular clay tiles going up on one side of the chimney and a hollow brick frame beside it. Can you describe what that frame is? Is there only one flue coming out of that chimney? Are you venting your two stoves from the same chimney - but in the end there will be two flues coming out of it?
I like the idea of having a mason doing the chimney or at least in my case, a chimney sweep busting out the tiles in my old chimney and installing the new liner. I don't know how it works for others, but for me, there are some things that I just need to PAY to have someone else do.
Looking good!
Bill
fossil said:Oh, well, c'mon...this project has a whole lot more to do with preserving the value of the home than it does with saving money burning wood. Rick
fossil said:A really good mason is an artist. I've tried to lay a few bricks before...built a little backyard fountain once. Ended up with more mortar on me than the bricks. Rick
