Don't know if this will help but the brick in my avatar is a inch or so out from the wall..and a row of brick near the top and bottom is spaced so there is air movement from top to bottom.
I used 1 " conduit screwed to the wall in vertical fashion. I spaced 3 of them equally and then screwed my corugated steel over it. Your can see my wall in the avatar. For my other wall protector, I used the same 1 " conduit, then screwed cement board to it. Then I tiled directly on the vertical cement board. Both came out nice. Good luck.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
