Bought a new house in December of 2016. Came with a EKO 40 in the barn, and a horizontal 1000 gallon storage tank in the basement. Last time I fooled with stoves was growing up and all we had was a coal stove in the living room to heat the entire house I grew up in. The system and I worked through a few kinks this past winter. They sure do not like moist wood! Ended up burning once per day to keep storage hot enough for the coils in my air handlers. Never tried the sidearm on my bigger water heater (a goal for this year).
I have read a lot of posts on this site and can easily see there is a wealth of extremely valuable knowledge being shared by some very smart folks. I have a lot to learn about this gasification heating system and hydronics, but would like to start with a few simple questions.
The EKO supplied tube cleaning tool does not seem adequate. Has anyone found a good steel or SST cleaning brush/rod that will do a better job of cleaning the tubes? I have plenty of room above the gasifier. My EKO is the standard model without turbolaters, and I plan to copy others on here who have installed the chains and rings.
The U-shaped bricks in the bottom of my unit are both cracked in half. Previous owner said they had been that way for a couple of years. I would not mind buying the new set from New Horizon, but it is hard to stomach the cost of shipping for these heavy items. I am not ready to pour my own as some on here have done, but would like to know if it is possible to get more life out of them by 'gluing' them back together with refractory mortar, and holding them together with SST band clamps? I noticed the new replacement bricks are a different shape. Anybody see a big difference in performance when they changed them from the U-shaped ones?
My system is pressurized with no antifreeze. Lack of freeze protection worries me. I have to travel fairly often. I generally leave the circulator for the air handler in the unheated attic running. It is operated by a hand switch anyway and not tied to a thermostat (more planned upgrades). But the circulator at the boiler in the barn does not run unless I am burning. I have read some where that the RK2011U controller has freeze protection built into it, but can't find that in any manual.
I have tried to attach a crude schematic of my system. Currently the 6 zone Taco relay panel is only controlling P4 via a signal from a 1st floor room thermostat. House was built in 2010, 2 story, 3900 sq. ft, full unfinished basement - heated by barely insulated storage tank. Any and all help/input is appreciated.
Kevin
Kevin
