2009 Jamestown J1000 Programmable Thermostat
RyanF
14
Northern Ontario
Hello Everyone,
I just bought a Jamestown J1000 pellet stove, and I wanted to install a programmable thermostat. I bought a thermostat designed for a central heating system, and was told it would work with the stove. The thermostat has the following labeled terminals, O/B, Y, R, G & W. The manual that came with the thermostat does not provide info on what any of these terminals do.
The stove has two screw terminals, unlabeled and the most info I can get from the manual is that these are to attach a thermostat. It does not tell me what type of thermostat or what leads to attach.
Has anyone used a Jamestown pellet stove with a programmable thermostat? I hope I can get this to work!!
Ryan
2 wires are normally the R and the W. (Transformer and heater)
O and B is for heat pumps and Y is for cooling, G is for optional fan
If the stove hookup is the same as most other pellet stoves, DannMarr is correct...use R & W connections. If there's a little jumper wire in there, you can remove that too.
So you don't get confused, R is the FEED to the thermostat and W is the LOAD to the unit.
Hi Guys,
Thanks for the replies. How do I know which is which on the pellet stove if they are not labeled. Is there a way to check with a voltmeter? How does the thermostat recieve the popwer it needs (I think its 24V)?
Thanks again,
Ryan
RyanF said:
Hi Guys,
Thanks again,
Ryan
Ryan, it doesn't matter which wire goes to what on the stove. The stat is just a "switch", and gets the power from the stove. Probably not 24v....most stoves/stats work on millivolts.
May I suggest a programmable T-stat. Well worth the money for people with busy life styles. Relatively cheap at around $30.00 at HD or Lowes these days.
I would have to go check but I am pretty sure my J1000 (manual light) is not 24VAC powered. Which means you need to take it back or you're in for some fun finding a 110VAC to 24VAC power cube or some other way to power it.
Find a programmable tstat that runs on batteries or a simple mercury tstat like the venerable round Honeywell.
Then remove the jumper on the stove, and just run two wires from R and W on the tstat to the terminals on the boards. And maybe a jumper using G so that you can override the tstat with its fan switch, if it has one.
