Corbon
I was wondering if anyone could comment on the quality, reliability, and issues with the Defiant 1610?
Wow... I wonder whats different about my wood. Running 24/7 my ash pan is full to the top every 2 days. Any longer and its starts overflowing into the ash pan chamber
Where does the cat thermo go?
We've spent so much re-doing the stove/hearth/chimney, whatever the thermo costs won't even matter at this point....
I haven't owned or operated one, but I have read some of the threads on the non-cat everburns such as the 1610. One of the biggest issues discussed was the soft refractory material disintegrating over time and being costly to replace. Another issue affected people with tall chimneys, the increased draft could cause some stoves to overheat.
Haven't heard any complaints about build quality, I'm sure the castings on that model are top notch like the ones on the VC's I have owned.
With the new parts, all you need is some good, dry, solid wood, and it should run great for you, and be totally predictable once you learn how all the variables affect the cat light-off. Stove top temp, wood dryness, how much wood gets burning in the temp ramp-up, all come into play. These are good, reliable heaters, and I love the ash-handling system. Too bad the window isn't a bit bigger.I've had mixed results burning this thing over the years (surprise, right?). As I read some of the posts here, I am already getting a better understanding of what it will take to get the most out of it more consistently. I can see that I really need to do a better job managing my wood supply. Right now I have some nice oak, but a lot of mixed stuff that is past its prime...
I'm not familiar with the newer style stoves but on my difiant and encore there is a plug just above the secondary air inlet on the back of the stove.Where does the cat thermo go?
I would suggest picking up the AT100 from Auber instruments. A digital display that tells the temp in numbers at all times. Plus it has two alarms. Really helps run the stove. Plus you don't have to look behind the stove everytime you want to know how hot you are running.speaking of cat thermometers, here is a picture of the VC supplied cat thermometer.
Does anyone know how the temp range compares? its odd that there are no numbers..... I think it looks pretty close to something like this, but can't really tell:
This maybe a dumb question but are you leaving a bed of ash in the firebox or sifting it all done to the ash pan on reloads?Wow... I wonder whats different about my wood. Running 24/7 my ash pan is full to the top every 2 days. Any longer and its starts overflowing into the ash pan chamber
While I have little experience with stoves other than this one, as a mechanic/maintenance guy for 30 + years I have had the opportunity to work on lots of different equipment. To me this is just trying to get a machine working right. With the rebuild, I now have the 'machine' back to original specs. Next is to control the variables. I just never really understood or thought about how big of a variable the wood quality is. I will 'get by' with the wood I have, but will be a lot more picky about what I bring home to feed the beast from now on. Probably even more of a factor than what I've been burning is what I do with it prior to putting it in the stove. I've had some laying in piles, some not even split, wood on ground, trees dropping debris on stacks etc. I plan to sort whatever I have left this spring and get anything solid off the ground and under cover. Not sure yet what that cover will be. Been checking out the shed thread for ideas. Also need to get a moisture reader. Luckily this is not my only or even primary heat source. I have a heat pump and oil burner. But they are not much fun to watch.With the new parts, all you need is some good, dry, solid wood, and it should run great for you, and be totally predictable once you learn how all the variables affect the cat light-off. Stove top temp, wood dryness, how much wood gets burning in the temp ramp-up, all come into play. These are good, reliable heaters, and I love the ash-handling system.
It is on the list, but right now not in the budget. I have a wish list of an AT100, griddle thermometer, pipe thermometer, new splitting axe, woodshed, decorative wood rack, dry wood, a few more feet of chimney, and a new chainsaw thats better for in-tree work....I would suggest picking up the AT100 from Auber instruments. A digital display that tells the temp in numbers at all times. Plus it has two alarms. Really helps run the stove. Plus you don't have to look behind the stove everytime you want to know how hot you are running.
The Fireview and Keystone also have the probe on the back. My install has the back of the stove about in the same plane as the fireplace opening, so it's hard to see. I bent a paper clip and wrapped it around the bolt in the dial face so I could look down from the top and have an idea where the probe needle was. At least then I didn't have to use a mirror.Plus you don't have to look behind the stove everytime you want to know how hot you are running.
Great. Sounds like you're a tech/mech nerd like me. Looking forward to detailed reports on the Brillo-pad combustor.as a mechanic/maintenance guy...just trying to get a machine working right.
Your wish list is about as long as mine. The at100 will be the cheapest thing on there for about 45 bucks. I ended up using the coupler from my condar digital thermo so I can not lead in the direction for one from Auber. A lot of people on here have the fiskars splitting axe. I chose to go the hand made route and got a gransfors bruk small splitting axe and must say I love it.It is on the list, but right now not in the budget. I have a wish list of an AT100, griddle thermometer, pipe thermometer, new splitting axe, woodshed, decorative wood rack, dry wood, a few more feet of chimney, and a new chainsaw thats better for in-tree work....
Yes I would see if that helps. They are temperamental. It's a love hate thing these VC stoves[emoji13]Ive always been in the habit of raking the coals forward at each reload to help the new wood light off quickly. That always dumps all the ash into the pan. Maybe I should stop doing that?
