Woke up this AM with stove off and no power light on panel, found blown fuse. Had cleaned burnpot day before and emptied ash pan. Restarted stove with no problems. Hours later found blown fuse, few ashes in burn pot and no unspent pellets. Thought auger must be jammed. Had pulled stove out of hearth, removed front door, etc. replaced fuse and turned on test mode.Distribution blower and combustion blower worked fine…....power light on for auger and igniter…......no auger movement, realized without frond door on pressure switch dosent close and auger and igniter wont work if I interperet schematic correctly. Installed door and closed it…......flash, blown fuse. Removed auger motor and auger and found jammed pellets , freed auger moves with no resistance now. Reinstalled new fuse, tried again,........flash. same thing…...Thinking now the motor must have shorted out during the jam, I replaced motor, (replacement motor did not have shaft and fan lade on the back of it, just a plate assy. whats up with that).....reinstalled ned fuse, tried again….......yup, you gessed it flash…..........Now Im confused. AnyIdeas on this one?......I know shorted out wires will lead to blown fuse conditions, but the stove was originally in hearth and running fine…....Not unless igniter crapped out which I have not checked out….....................HELP
