Accentra Low Flame / reduced heat output
deadenzo
4
Southern, NH
Stove Newbie here...
I had a free-standing Accentra installed in mid December 2010 with OAK. I was surprised how much heat that it put out. Pellets are Cubex and Greene Team. Running on stove temp 4, feed rate 4. At that setting under 20* outside temp I can maintain close to 70* on the first floor. I scrape burn pot nightly to break up any carbon build-up.
I clean it weekly and haven't had any issues with small flames/reduced heat output, but has been since the last clean on Sunday. What I did on Sunday, in addition to normal clean, was to pull the vertical panels (on either side of burn pot) and brushed and cleared ash from behind those. There was a fair amount of ash back there, but not too much. I thought that would be a good thing, but ever since this clean I am struggling to get anywhere near 70* on stove temp 5-6 and/or room temp 75*. Any suggestions?
Tom
You pulled the covers for the heat exchanger and brush cleaned them. You now have to finish the job. Start by unplugging the stove, removing the covers again, and this time removing the lower combustion fan housing, the part the heat exchanger covers sit on. Should be 2 swing latches, similar to those on top. This will give you access to the outlet towards the left. Clean inside, remembering to watch out for the temperature probe about 3/4 of the way back. On the right you will see a fan, carefully clean behind this, don't bend the flimsy blades. When you button this back up take the time to loosen the 2 thumb screws on the front of the the burn pot and clean inside the igniter area. This is still not a thorough cleaning, but should get you through the winter.
Thanks for the suggestion. I'll clean the ignitor box too. I did that as part of my weekly cleaning, but it won't hurt.
Thanks,
Tom
ok, so I went through and cleaned the stove again.
When temps outside are above 25* it seems to produce pretty good heat ~70* when set on stove setting 5 (of 7) with feed rate also 5. When it goes below 25* I cannot seem to keep it above 64* degrees. Same Cubex pellets, scraping burn pot daily twice. (ESP probe was already replaced once a few weeks after initial install.)
I'm stuck on the fact that since I had the OAK installed the fire is smaller and the heat output seems reduced. Dealer says it's cold outside that's why you're getting reduced heat.
Any other suggestions of things to check?
Thanks
you say you added the OAK? if so, just do an experiment of removing the air intake pipe from the stove (plug it with something so you dont get a draft from the tube) and see how the stove responds.
