Add on wood boiler to LP furnance
searlest
13
NE indiana
Hello to all and Thanks in advance!!
I am starting to do research for the purchase of some type of wood burner to heat a two story brick house that was built in the mid 1800s (walls are 12 to 16 " thick all brick.
My current main heating source is a LP gas forced air furnance.
Pleas give ideas on the best way to incirprate a wood heating source.
One important note is that I some times travel for work and can not always be home to fuel the fire so my LP furnnace will probaly need to stay as a back up.
If you have read through much of this forum, you have probably discovered we are fond of gassifiers. My suggestion would be a gassifier like the Tarm, Eko, Econoburn, etc in the basement or in an out building. Leave the existing LP in place and get a heat exchanger that goes in the duct work for it to heat off of the new add on boiler. That way the LP takes over when you are out of town. You could also add heat storage and have someone do burns for you while you are away.
You would add a new thermostat next to the existing one which controls the new hx coil and the units fan. The existing thermostat is set lower so that it will automatically take over when the wood boiler runs out.
Do you have a servicable chimney with an extra flue? Do you have easy access to basement? etc.
