This can be done, It depends on how the old one was installed, facia covering, access to the rear, hearth, etc. If the goal is to keep as much intact as possible, then easy rear access and a lot of careful measuring is where to start.
Problem is if you take one out you can what do you do then? Can you get a different ZC in with the existing structure/dimensions?
I solved the problem. Installing a Lopi Insert.
There have been a few that came here for advice and made the switch. If the enclosure size, basic framing, and opening size is similar then it's possible though easier with rear access.
That will be different than what @triceps is considering if a freestanding stove is to be vented via a liner thru the ZC. The main factor with what he has proposed is the lintel height.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
