    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. I was under the impression that leaving the air control open was sending too much heat up the stack. I know it allows more air in and creates a higher rate of combustion prior to secondaries, but does that air being open more during start-up / re-load actually send heat up the stack versus closing down the control sooner?
    #1
    Helpful Sponsor Ads!
  2. HotCoals Minister of Fire
    Rochester,Ny.
    Yes..but you have to heat things up!
  3. corey21 Minister of Fire
    Soutwest VA
    More air is needed to start a fire or reload to bring the stove to a certain temp then you start adjusting it.
  4. So it does use more fuel, but is necessary for a good burn. Like accelerating a car to merge onto the highway?
  5. corey21 Minister of Fire
    Soutwest VA
    I think you nailed it.
  6. Backwoods Savage Minister of Fire
    Michigan
    Right. Also don't forget that on reloads as well as starting a cold stove, lots of moisture goes up the chimney at the start of the fire so the extra draft is good to send that out into outer space.
  7. i never knew that. makes sense though.
