air intake..
chrisasst Posted By chrisasst, Oct 28, 2008 at 2:51 PM
Thread Status:
  1. chrisasst
    chrisasst
    Minister of Fire 2.
    NULL
    Aug 13, 2008
    1,276
    22
    Loc:
    cortland ny
    Ok this is probably dumb question, but I can never figure this out. Do I get more heat if I have more air intake or less air intake. That is one of my down falls, I can never figure out the proper air adjustment. Also does more air = more pellets burned?
  2. imacman
    imacman
    Guest 2.
    NULL
    Chris, IMO, the more air you introduce into the burn the hotter and FASTER the pellets will burn....there's no free lunch.
  3. Xena
    Xena
    Minister of Fire 2.
    NULL
    Nov 30, 2005
    2,494
    92
    Loc:
    South Shore MA
    I found that I was able to control the burn
    better with an outside air kit...
    I went the first three years using inside air.
    The biggest issue I noticed was, a cold
    draft across the floor. Room would be 75F,
    my feet would be cold due to that draft.
    Last week I connected a fresh air intake to the
    outside. Cold draft at floor level is gone.
    So imo if you can but haven't already, try to
    set up a hose to the outside your better off.
  4. slls
    slls
    Minister of Fire 2.
    NULL
    Jun 9, 2008
    1,497
    53
    Loc:
    central maine Lat 45
    The best way to set air is to close it till a smoky and lazy flame, then open the air slowly until it clears up and the flame is bright. If the stove gets sooty too little air, blow torch flame too much air. The right air setting will give maximum efficiency for what ever quantity of pellets burned.
Thread Status:
