Antifreeze
Czech Posted By Czech, Dec 11, 2009 at 3:31 AM
Thread Status:
  1. Czech
    Czech
    Minister of Fire 2.
    NULL
    Jan 20, 2006
    1,065
    13
    Loc:
    Twin Cities, MN
    Yeah, it got a bit cold up here, doing the usual maint. I ended up putting the Dex Cool orange antifreeze in my CA 2004 Titan reservoir that I just drove home to MN in Sept, looked like there was the green stuff in there. Any concerns? Darn VW that the wife drives always gets me, I'm old school I guess.
  2. dave11
    dave11
    Minister of Fire 2.
    NULL
    May 25, 2008
    615
    10
    Loc:
    Western PA
    This is a big area of contention, the mixing of Dexcool with other antifreeze formulations. The big issue in recent years is the adding of the standard green to Dexcool, which was a suspected cause of dexcool turning to grit and ruining the cooling systems on GM cars/trucks.
    Probably if you didn't add much, not much will happen, though the car's cooling system was not designed around Dexcool, and this might be a good time to flush the coolant, which should be done regularly anyway.
    How much dexcool did you add?
  3. Fi-Q
    Fi-Q
    Feeling the Heat 2.
    NULL
    Mar 5, 2009
    275
    37
    Loc:
    Bonaventure, Quebec
    Honnestly, don'T take any chance... ask you'Re dealer and go for a anti-frezze flush & wash.
  4. Czech
    Czech
    Minister of Fire 2.
    NULL
    Jan 20, 2006
    1,065
    13
    Loc:
    Twin Cities, MN
    Added around a cup or two, just topped off the reservoir. The coolant is fairly new so I didn't want to flush if it was ok. Thanks for the replies!
  5. dave11
    dave11
    Minister of Fire 2.
    NULL
    May 25, 2008
    615
    10
    Loc:
    Western PA
    A cup or two is pretty small compared to the overall amount in the cooling system.
    You could look in your owners manual for the name of the specific coolant your car was designed to have, then look online to see if Dexcool is compatible. They will probably say it isn't, because they assume you're replacing all the coolant with dexcool, which you certainly don't want to do.
    It's probably fine, but if you're worried, have it flushed and replaced. Great preventive maintenance anyway. If the car is more than four years old, replace the radiator cap as well. Very important.
  6. pen
    pen
    There are some who call me...mod. 2.
    NULL
    Staff Member
    Aug 2, 2007
    7,778
    1,532
    Loc:
    N.E. Penna
    If it were me i'd drain it and replace w/ clean antifreeze. Whether it be rumor or not, truth or wives-tale, I've heard from several mechanics that not only dislike dexcool but speak of the problems they've seen w/ them mixing causing waterpump failure and plugged heater cores.
    Drain and replace for peace of mind.
    pen
  7. Highbeam
    Highbeam
    Minister of Fire 2.
    NULL
    Dec 28, 2006
    12,354
    2,092
    Loc:
    Cascade Foothills, WA
    Did you run the engine? If you just added the cup to the res then you would be safe to just remove the res and clean it. I like dexcool, have had great luck with it so long as I flushed it regularly in GM trucks. I would not want to mix ANY antifreeze colors. That's the cardinal rule of antifreeze, don't mix colors. If you ran it and now the res is the same color as the radiator then do the flush. It's not worth ruining a cooling system. Think water pump, thermostat gasket, all hoses rotting out, head gaskets, plugged up coolant passages, etc. Nothing pretty about that.
  8. dave11
    dave11
    Minister of Fire 2.
    NULL
    May 25, 2008
    615
    10
    Loc:
    Western PA
    Well, I'm not sure there's any definite proof that the different antifreezes react together in any damaging way. The reason there are different colors and makers is because each manufacturer makes their cars differently, and so the cooling systems vary in terms of the types of corrosion protection needed. GM uses dexcool, others use the various other formulations. But the difference is the way in which they protect from corrosion, not in the way they transfer/release heat.
    So worst case scenario, you'd be getting less corrosion protection than you need, by using the wrong coolant. Two cups in a 3-4 gallon system likely won't make any difference.
    Last I reviewed this, the idea that dexcool turned to gunk from being mixed with traditional antifreeze had been dis-proven. I have experience with it, because I was one of the first people to have it happen, and no green antifreeze had ever been added.
  9. Czech
    Czech
    Minister of Fire 2.
    NULL
    Jan 20, 2006
    1,065
    13
    Loc:
    Twin Cities, MN
    Thanks again all, I'll take a look at the reservoir tonight as I did run it today. I was thinking like dave, figured the volume was not that big of an issue, but again I appreciate all the advice. One other thing, I did pick some green stuff up today, I will pour half and half into a mason jar and see what happens!
  10. dave11
    dave11
    Minister of Fire 2.
    NULL
    May 25, 2008
    615
    10
    Loc:
    Western PA
    Probably will get a weird-o color, but nothing else. For a fair test, you'd need to heat it to 220F or so anyway.
Thread Status:
