Ash Pan
Curve Posted By Curve, Mar 15, 2013 at 4:16 PM
  1. Curve
    Curve
    New Member 2.
    NULL
    Oct 13, 2012
    47
    1
    Loc:
    Central, MA
    I have a VistaFlame VF-55. I am new to Pellet Stoves, installed this stove in October. I clean the stove about every 2 weeks.
    Can I open the Ash Door without shutting the stove down? Can I open the Fire Box glass door without shutting the stove down?
  2. briansol
    briansol
    Minister of Fire 2.
    NULL
    Jan 18, 2009
    1,913
    293
    Loc:
    central ct
    Not sure of your exact model stove.... generally you can, but generally you shouldn't :)
    I only open my door while its on to scoop quickly out the burn pot if it got clinkered up.
    any other case, i shut it down for an hour, usually 2 or 3 to be safe, before vacuuming it out/etc.
  3. hossthehermit
    hossthehermit
    Minister of Fire 2.
    NULL
    May 17, 2008
    2,568
    533
    Loc:
    Maine, ayuh, by gorry
    Not meant to be rude, BUT, your owner's manual is your friend.
  4. stovelark
    stovelark
    Minister of Fire 2.
    NULL
    Oct 10, 2009
    1,121
    200
    Loc:
    SE CT
    Curve not a good idea to open door for anything other than to clear a clinker, and since you have the agitator, you should be all set. Remember, when you open ash door or front door, you'll lose vacuum after a bit and the stove will stop feeding. I'd suggest cleaning it all out at once after its been turned off and cools down. Good luck.
    Stovelark
    Enviro Empress FPI AC
    Enviro EF3 FS pellet
    Enviro Kodiak 1700 FS wood
  5. subsailor
    subsailor
    Minister of Fire 2.
    NULL
    Dec 8, 2011
    1,420
    384
    Loc:
    Winthrop, Maine
    Harman manual says you can remove the ash pan and empty it without shutting the stove down. I open my firebox door every day to scrape the burn pot.
  6. stovelark
    stovelark
    Minister of Fire 2.
    NULL
    Oct 10, 2009
    1,121
    200
    Loc:
    SE CT
    Hey sub- speaking in generalities, usually not a good idea to operate on a stove that is burning unless it needs to be done, IE breaking up a clinker in a burnpot, knocking down ash built up around burnpot etc etc. Its prob ok to do but not generally done. Does your Harman use a neg vauum or positive vacuum switch?? Sounds like it might be positive if it continues to feed with the doors open. Sherwood stoves use neg vacuum, after about 25-30 seconds, if a door is still open, it normally stops feeding (safety switch). Anyway, good luck to us all.
    Stovelark
  7. corkman
    corkman
    Minister of Fire 2.
    NULL
    Dec 3, 2009
    592
    92
    Loc:
    SE,Mass
    i have the same stove and i am curious as to why you would need to do this. agitator clears the pot so clinkers should not be an issue.what ya got going on there Curve
  8. Melissa220
    Melissa220
    Feeling the Heat 2.
    NULL
    Aug 10, 2012
    361
    113
    Loc:
    central ME
    The stove does not continue to feed, and the fire continues to burn. However, if the firebox door were left open for too long - 3 minutes I believe - the stove would go into shut down mode. Same as if the pellet hopper were open for more than 3 minutes.
  9. stovelark
    stovelark
    Minister of Fire 2.
    NULL
    Oct 10, 2009
    1,121
    200
    Loc:
    SE CT
    Melissa thanks for info, didnt think Harmans would be any different- only worked on a few.
  10. Curve
    Curve
    New Member 2.
    NULL
    Oct 13, 2012
    47
    1
    Loc:
    Central, MA
    When the stove is on heat level 1 ash tends to build up on the sides of the burn pot. It normally will blow off when the T-Stat turns the stove back to level 3 (this is the highest setting I use), however sometimes I would just like to open the fire box door and push the ash from the edges of the burn pot. I never seem to have issues with clinkers because of the agitator.
  11. glenc0322
    glenc0322
    Minister of Fire 2.
    NULL
    Dec 30, 2011
    605
    86
    Loc:
    long Island NY
    Just because you can do something doesn't always mean you should
  12. jtakeman
    jtakeman
    Minister of Fire 2.
    NULL
    Dec 30, 2008
    13,497
    1,573
    Loc:
    Northwestern CT.
    Curve, The ash build up on the sides isn't a big deal. No real need to worry. It will still burn for days without issue's. Instead of opening the door to fiddle, Just move the mode switch to manual(stove will go to the higher setting) for about 20 minutes if you must. Then move it back to hi/lo. Should blow all the excess over the edge to the ash pan.
