Heating about 1500 sqft. Will I need a blower? Not really wanting the extra stuff on the back of the stove. Stove is on middle floor and will need to heat the up staris area hall way and three bedrooms. Ceilings are vaulted.
Blowers are always a plus, especially on stoves that are already more convective. But that's my opinion. I use mine almost all the time.
You can always try without, and add them later. Depending on you rear clearance, you may need the rear heat shield if you choose to not add the blowers.
Vaulted ceilings present a challenge. Heat will stratify and sit up high in the ceiling peak. Do you have a ceiling fan in the stove room? If yes, that will help. If not, having the blower on the stove will aid heat circulation. If you can post a sketch of the floorplan we may be able to make better suggestions.
This stove already has a very close clearance! 6" to the air box on the back is close enough I would think. Do thy even offer a rear shield for this stove? I haven't seen one.
The optional fan kit on the ashford changes the depth dimension from 29-3/8 to 31-1/8". There is a rear shield available as some installs require a rear shield or fan kit. It does look like the standard non-alcove install does not benefit from having either.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
