    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. brian89gp Feeling the Heat
    Kansas City
    Does anybody know if asian bush honeysuckle makes decent firewood? I know it is extremely tough stuff and is pretty hard to cut by hand. The larger stuff gets to 4-6" diameter and 20ft tall
    #1
    Helpful Sponsor Ads!
  2. bogydave Minister of Fire
    So Cent ALASKA
    Never heard of it.
    If it's free & easy to get:
    It's wood.
    It's BTUs.
    When seasoned & dry; it'll burn & produce heat ;)
    Try it :)
  3. k9brain Member
    Jersey Shore
    Looks like you need to take one for the team and tell us how it burns.
  4. Blue Vomit Minister of Fire
    eastern PA
    Did you just make that up?
  5. brian89gp Feeling the Heat
    Kansas City
    Make what part up?
  6. brian89gp Feeling the Heat
    Kansas City
    Burned some today in the outside pit, it burns better then the silver maple of the same diameter but not as good as the honey locust that I have (as far as heat and longetivity). It was a bunch of 2" diameter stuff, counted about 10 rings per inch.
    Only reason I ask is that there is a huge amount around here and I will be clearing some of it out this winter. They are usually limbless for the 2+" diameter section and it would be trivial to cut once or twice more and collect it to burn.
  7. Brewmonster Member
    Central NJ
    That stuff is so invasive, I hope it is good firewood. If you keep cutting it, maybe it will die!
