Back-puffing in a Resolute Acclaim
RAC
1
Vermont
I have been burning my Resolute Acclaim for 12 years old with a one year old replacement secondary combustion chamber. I thought the replacement chamber would eliminate my back-puffing but it has not.
My wood is at least 1 year old and under cover for at least 6 months. My chimney is masonry, cleaned annually [even though my cleaner claims it could go 2-3 years]. The stove has an outside air supply that vents immediately below the stove. I routinely clean the ash pit and the circular holes in the secondary combustion chamber. I can eliminate the back-puffing by burning the newly charged wood up to 500 degrees, closing the damper and leaving the bottom vent open in the high [not the start up] position. The problem is the stove runs out i.e...the coals diminish, and the stove temp. drops below 300 degrees in 4-5 hours as opposed to 7-8 hours if I adjust the vent much further to the closed position. The other concerns are that with this back-puffing elimination strategy the room gets too warm at times and the stove is cold in the morning, i.e. no coals left to restart the stove.
Any suggestions?
