I didnt think of that ,the weight possibly sagging the burn tubes. They get pretty hot, so sagging is a real possibility.That said, any rod added that has any weight to it at all certainly should be put on the sides of the baffle where it has more support, and not in the center where it's weight could potentially stress the burn tubes and cause sagging.
pen
Mine are doing that too.I figure at some point you could take them out and flip them over. It dont seem to affect performance at all so, no sweat over that.Looked up at my baffles again tonight, and they appear to have warped a bit. There's a good 1/4" gap between the top of the front tube and the bottom of each baffle. This is all the way across, and it doesn't look like the tube has sagged at all. Hmm...
I just took the performance up another level.It never hurts to play around, but in the scheme of things, I doubt you'll see any real difference. I ran for years without sealing it up, and personally noticed no real difference after doing it with the gasket rope and rod.
pen
No 1. I sealed up some draft leaks around my chimney cleanout. Made a big difference.
No2 I put the rod on the side and turned the baffle boards around so they fit tighter.
Needless to say the stove performs even better. I can now run the stove exclusively on minimum air and still get a hot stovetop and blazing secondaries.This never happened before in the 3 years iv been running the stove. Its all about the draft and a tight baffle board dont hurt either.
Needless to say the screw holding the front air tube broke off in the stove,so i put a screw in the air hole on the right side of the tube in one of the air holes closest to the right side so the tube wont work its way right and fall out. I guess the correct way is to drill out the broken screw but this was quicker.
The boards were already cupped after about 1 year,stove is 3 Yrs old. I just flipped them over so they should flatten out. I only recently added the rod a few days ago. Be careful if you do this(flip boards) cuz they are fragile. Pen said its common for them to cup and then eventually flatten out. I fully expected the screw to break off,which it did. Not wanting to spend the time drilling it out(ill do that later),I just reinstalled the tube in the correct position and put a screw in the first air hole on the right to stop the tube from backing out and falling into the stove.No cupping yet but I haven't sealed the edges with a rod either. Do you think the cupping is related?
I noticed that you have to remove the screw to get the baffles out for cleaning and that the screw looks small and easy to seize. That screw not only retains the tube but also fixes the angle of the air holes. It needs to be right. Is the screw breaking a common thing?
Was the First time i ever took a tube out. Screw was tight from the factory and broke off trying to take it out.Max stovetop so far is just over 700 but the way she is runnin now that may go up. Increasing the draft seems to turbo-charge this stove.Finger tight is enough with the screws folks.
And don't tell me I ain't getting it hot enough. Only one here that has admitted a grand stovetop in one of'em
This is a very interesting topic to me, as I have been debating insulating my 30' liner. I have to run the stove at 525+ to be able to damper it down to low draft and have nice secondaries with no smoke from the chimney. I wonder if I insulated my liner if I would be able to damper it down to low draft at a lower stovetemp and get full roaring secondaries if I insulated the flue?
Im pushing for a HOTTER stovetop with a LOWER air setting. After all the idea is to get more heat and a cleaner burn. Thats what i seem to be getting with the improvements i made.I wonder if I insulated my liner if I would be able to damper it down to low draft at a lower stovetemp and get full roaring secondaries if I insulated the flue?
