I found a guy willing to drop off a lot of wood. Most of it is oak and by the looks of it, they are 3-4 ft logs and about 36" diameter. Here's my question:
I'm a newb with a craftsman 18" saw, I go through chains like crazy because i love hitting dirt. I have a Ariens 22 ton splitter with vertical operation. Can i process this with the equipment i have or am i biting off more than i can chew. He estimates 5 cords of wood, looks like more to me. He'll deliver it to me for $20.
Thoughts?
Keep in mind that it will destroy whatever is under it when it is dumped. Hopefully you don't have built in sprinkler heads or were thinking of getting it dumped on pavement. You will also wind up with a lot of short pieces after you cut it up.
Ok, checked out site again and got some pics, please give me some input based on the pics including wood type. He said there is some pine but I didn't see any.
That's what I hate about tree man chunks. Especially the 18" ones that need 2" taken off them. Keep your eye out for a guy with a log truck. There are a lot fewer oddball lengths in a log load and it amounts to almost the same amount of cutting. If you can get that wood for $20 I would hazard a guess that there is an outfit in your area with a log truck and the same or lower price. (The price is infinitely lower here ).I already have tons of chubs. smalls really screw up my stacks, i really dont' know what to do with them.
There is a lot of wood there wrapped in vines. Can't just remove the vines? or the bark?
Wait... let's not get carried away, here. The oil in poison sumac is the same as the oil in poison ivy, urishoil. I suspect the bad rash you got from poison sumac would have been the same if you were in contact with poison ivy.Not poison ivy. That is poison sumac. it is nasty shtuff. I have had it a few times and it is as bad or worse that ivy. This wood likely came from a low lying swampy area. That is where poison sumac grows. In the first picture you can see the tiny white/yellow berries that are the give away for sumac.
Note: don't burn the vine. Don't burn the wood that the big vine was attached to. The smoke if inhaled can cause a significant respiratory response. You can die from it. bad news.
I once got into this stuff by accident when installing a tree stand for hunting. No fun.
I just threw together a bin made out of t-posts and woven-wire fence, enough to go around a couple of pallets, tossed 'em in there to dry out, and burned on the pile during the shoulder season when I just needed little chill-buster fires.I already have tons of chubs. smalls really screw up my stacks, i really dont' know what to do with them.
Poison Sumac is a small shrub, not a vine that grows on trees.
Ditto. However, one time I did make the mistake of getting too friendly with it.Why is everyone getting their pannies in a bunch over some vines? I rip poison ivy off of wood just about every time I get it, no big deal. I've been burning ash all winter long with little poison ivy hairies on it, no big deal.
