- Oct 27, 2012
- 43
ok i will try to get this answered... last time the thread got derailed because of safety concerns of my install, now that i got it fixed lets try again
this is kind of a tricky question so i will try to explain as best i can. first off i am going to post a pick of the stock thermometer i have on my stove. , i am assuming it is cat therm. because it is rite behind the cat on my stove but anyway here is the pic and when i refer to this particular thermometer i am going to refer to times because it doesnt have degrees on it.![[Hearth.com] BK Cat temps in relation to stove temps [Hearth.com] BK Cat temps in relation to stove temps](https://www.hearth.com/talk/data/attachments/86/86584-1fc0de53d7c89fc052643ec8a289b528.jpg?hash=TjpVe4W-UG)
so noon would be the mark rite before active at the top.
i am trying to decide how to burn it to reduce creosote, burn at an optimal temp. i also have a magnetic thermometer on my single wall stove pipe about 18 inches above stove.
ok here goes.
when my blaze king thermometer reaches say around 2:00 oclock in the active zone my stove pipe is near 325 to 350 degrees which is optimal burning temps from what i read. but! this stove has a thermostat which will cut the air down when it reaches a certain temp. and the fire will seem to completly go out for awhile and come back on when it cools down.. the way i have the thermostat set is it reaches 2:00 then goes out and lets air in and starts a burn again at noon.. but when the fire goes out the magnetic stove pipe temp goes down to 250 degrees and usually stays there and never really returns to optimal burn temp at 300 or above!
now with that info can i make any assumptions about these temps? does this tell me anything about cat? maybe cat isnt working? just kind of curious because i thought with the cat pipe temps should stay above the 300 degree temp? or am i wrong? just asking for some expertise!
now i know some are going to say my place is to small for stove, that may be, but., by what the cat thermometer is saying i cant burn it to much hotter than i am now.. i dont want to overburn it.. 2:00 seems like it would be a good burn point? correct me if i am wrong.
ok here goes.
