    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Laura Syria New Member
    Hi All. New here:). Very happy to find a place to help me solve our wood stove issues.
    My first question has to do with the area around our Woodstock. The floor behind it is covered with black stuff. And the wall behind it is covered in black specks. What is causing this? And how do we fix it?
    Thanks,
    Laura
    #1
    Helpful Sponsor Ads!
  2. BrowningBAR Minister of Fire
    Doylestown, PA
    Could you post some pictures? My first thought is that of health concerns.
  3. Laura Syria New Member
  4. tfdchief Minister of Fire
    Tuscola, IL
    Should not be any black stuff????? Pics?
  5. Laura Syria New Member
    I will post pictures tomorrow. What sorts of health concerns are you imagining?
  6. BrowningBAR Minister of Fire
    Doylestown, PA
    Carbon monoxide.
    Worse case is that, however the stove is vented/connected, is blowing back to some degree and the black stuff is ash and creosote.
  7. Scotty Overkill firewood hoarder
    central PA
    Is it powdery black stuff or does it look like it's dripping ? if it looks like it's dripping, you've got more than one problem. You have a leaky flue pipe, plus you are burning wood that is not seasoned.
  8. Laura Syria New Member
    We have carbon monoxide detectors. That shouldn't be a problem. The ventilation sounds more likely. Is there a secret formula to making sure the pipe is such that the flow stays headed out?
  9. Laura Syria New Member
    It is powdery, not drippy.
  10. tfdchief Minister of Fire
    Tuscola, IL
    And likely the stove connector is put together backwards.....otherwise no creosote can drip anywhere but down the connector and into the stove.
    A1Stoves.com and Scotty Overkill like this.
  11. Scotty Overkill firewood hoarder
    central PA
    you're exactly right, chief! I bet all her inside pipe is on backwards. Easy fix, if that's the case. But still, she's burning wet wood by the sound of it...
  12. tfdchief Minister of Fire
    Tuscola, IL
    Hope not, but it doesn't sound good. Get us some pics for sure.
    Scotty Overkill likes this.
  13. seeyal8r Feeling the Heat
    North Central Oklahoma
    The only black stuff I've ever had with my insert was when I cleaned the chimney liner. Ashes are grey but some of the buildup in the chimney liner came down as a very thin black powder. Either way you shouldn't be getting it in the house.
  14. Backwoods Savage Minister of Fire
    Michigan
    Also, how is the flue. Horizontal out the back or with an elbow then up?
  15. A1Stoves.com Feeling the Heat
    Northern CA
    +1
    its very common for the connector at the ceiling box to be upside down-even if all the rest is correct.
  16. Hass Combustion Analyzer
    Alabama, NY
    Upside down to us may be right side up to others. Since technically the ceiling box connector is the opposite way of the rest of the chimney connects. So someone just piecing parts together may not realize you have to reverse the way the chimney connector goes in.
  17. tfdchief Minister of Fire
    Tuscola, IL
    I am not sure I understand what you are saying. The class A has its own system of connecting together depending on the brand. The entire chimney connector from the Class A to the stove goes together with crimped ends down and inside the section below it, including the ceiling box connector, which is the first piece in the chimney connector.
    A1Stoves.com likes this.
