Lanning said:Jason, did you replace the door gasket or just tighten the door latch?
His door latch broke while he was trying to tighten the old gasket. He later put in a new gasket.
Thanks all, for a very interesting and educational thread. As with many disasters, this one seems to be a cascade of smaller issues, that gang up.
To recap, for my understanding, future readers, and comment:
1. Blaze King Princess started burning poorly, first burning too slow, then burning too fast. A sticking thermostat was suspected.
2. Thermostat removed, and cleaned of excess silicone sealant, which might have been causing the sticking.
2a. Door gasket slightly loose in one place (dollar can be tugged out), handle breaks trying to tighten, user fixes handle but cannot fix looseness.
3. Thermostat reinstalled, without sealant around the base, perhaps allowing an air leak bypassing the thermostat air control.
4. Stove performs poorly, thermostat appears to never move--perhaps never getting warm, perhaps sticking.
5. New thermostat installed as in 3, same results as in 4.
6. Chimney cleaned of minor buildup, door gasket replaced and tightened to fix looseness, thermostat reinstalled with silicone sealant around base to seal suspected leak bypassing thermostat.
7. Stove appears to function normally.
I see two take-aways: BK door gaskets should be checked and maintained religiously, and replaced thermostats should be carefully sealed around the base--enough to prevent leaks, but avoiding excess that could bind the thermostat.
HTH. Comments?
