FPX 33 insert?Is there a chance that ash build up my affect thermostat behavior . It takes much longer time for fan to kick in on my Travis FPX if I got bed of ash since the sensor is under firebox.
Seems like it. Not 20 minutes later and the flames returned. The flapper looks like it's in the same position as before.Thermostatic operation of an insert has to be challenging.
I wouldn't leave it on high for an hour if I was looking for long burns. I shut mine down as soon as the cat is active. Except for about once a week to burn the firebox out, or when I'm starting a new fire and the house is cold.I've been playing around with th Sirraco this morning. I emptied out all the ash from it and started a fire. Got a good one going and shut the bypass when it was hot enough. After about 2 hours I left the house and there were very little flames. Returned home a few hours later and still very little flames and th cat just in ththe active zone. There was a little bit of wood left, so I decided to reload it.
Put some splits on it and kept it wide open to allow them to char. After an hour I brought the T-stat down again and checked it. It was partially closed (similar to the what I saw with hair drier test) and there was some flames.
I pushed down on th flapper to shut it and the flames died immediately. When I let up with my finger the flames didn't come back, even though th flapper opened up again. The cat really took off and is glowing away. The needle is higher than I have seen it yet.
I still wonder what I need to do to get the stove to shut down like this on its own?
The stove top is about 650 F, the ash shelf is about 250 F and the aluminum block around the t-stat is 135. Seems like there isn't enough heat being transferred down around the t-stat.
I typically don't keep it on high that long, I was just hoping to get the insert good and heated up to try and get heat down to the t-stat.I wouldn't leave it on high for an hour if I was looking for long burns. I shut mine down as soon as the cat is active. Except for about once a week to burn the firebox out, or when I'm starting a new fire and the house is cold.
I seeI typically don't keep it on high that long, I was just hoping to get the insert good and heated up to try and get heat down to the t-stat.
When I removed the cat from my Powerstroke wife said There goes your warranty!
Mine too. 7.3 6 Manual, red lines at 8mph in lower gear 4WDThe best powerstrokes never had cats Mine is a 2000.
Do you have a picture of your this upgrade latch?I get the same milage with my pi as well! I installed the new style latch today. I definitely recommend it as an upgrade.
OK, here's what my stove did. It was about 37 last night, 42 today. It's 72 in here, house isn't well-insulated or air-sealed. Here's what I have left after a load of Black Cherry and Sugar Maple, loaded at 7:30 AM.I do not wish to rub salt in your wounds, but it was similarly warm here today (45 overnight, 55 by day), so I burned my Princess insert nearly as low as I could, no fan. Loaded it around 7 PM yesterday. Here it is at reload time, 4 PM the next day. I think that might have gone 30 hours if some jerk hadn't opened to door to play with it.
Don't even make me pack a load of Black Locust and Dogwood!wasn't great wood, and it wasn't tightly packed
