    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. oldgrezmonke New Member
    Finger TN
    We are looking at an 60-70 year old rural house that we might buy . Out in the back yard is a good sized metal tube [@18-24" dia.] sticking straight up about a foot with a slightly rusted through lid that is equipped to be padlocked . I have not yet looked into this thing . I don't think it's a bomb shelter as there should be vents some where near and the tube doesn't look big enough to climb down . There are two things I think it might be : an old cesspool [maybe a septic tank ?] or an old buried propane tank . I know what I would see if it is a propane tank . If it is a cesspool or septic tank , I presume I would see and probably smell [yes , I know to let it ventilate before looking inside] human waste-does anyone know if there is any visual difference likely between the two that would be visible from such an access point ? I will be contacting the real estate agent before/if we decide to take another look but I want to be prepared to try to figure it out myself if need be . Sorry , I don't have any pictures . I have searched the internet and cannot find anything that looks like this . Thanks for any ideas .
    #1
    Helpful Sponsor Ads!
  2. JustWood Minister of Fire
    Arrow Bridge,NY
    Could be a dry well.
    Sounds like a flashlite and bolt cutters are your best bet. Close it back up with a bolt and lock nut.
  3. oldgrezmonke New Member
    Finger TN
    Flashlight-definitely , bolt cutters-no need , it has a hasp for a padlock but no padlock , just a really old tire [think model A Ford] and a large rock on top . A dry well would be better than two of the possibilities . Have you seen something like this that was a dry well ?
  4. JustWood Minister of Fire
    Arrow Bridge,NY
    There is a few farms around here that have them for irrigation purposes. Could be a mine vent also.
  5. bsruther Feeling the Heat
    Northern Kentucky
    That's where they keep the bodies.
  6. Corey Minister of Fire
    Midwest
    First, I'd be extremely careful if you actually intend to enter the space. There are gasses that are odorless, colorless, etc and heavier than air...methane, CO2, etc. You could go in, pass out and never come back up. Worst part is if someone comes to your rescue, they could suffer the same fate. Probably not a bad idea to have someone standing by and instruct them not to come in after you but to get additional help. Anyway...
    I don't think you'd actually be able to crawl into a propane tank. Those are pressure vessels so there isn't likely to be a hatch that a man could get through. Propane tank would also have hemispherical ends - again due to the pressure, while any type of septic tank or other storage tank, I suspect, would have simple flat ends. It could also be an old cistern...possibly with ties to the house gutters for fresh water storage. Those are pretty common on older houses (and newer 'green' buildings ironically)
  7. oldgrezmonke New Member
    Finger TN
    I have no intent to enter the space as I am aware of the asphyxiation risk-just open the lid , wait a few moments for any noxious gases to dissipate , take a deep breath , then peep in to get an idea . If it should be a buried propane tank , there would be valves and plumbing inside . This thing is too far from the house to be a cistern .
  8. oldgrezmonke New Member
    Finger TN
    I do not have access to a camcorder . Perhaps I could borrow my son's cellphone which has a camera . Drop a rock or two first to see if it goes "plop" or "clink" is a good idea , too . I could do either or both of those without my face over the opening .
  9. kenny chaos Minister of Fire
    Rochester,ny
    Ask the owner? We have disclosure laws in NY.
    I agree with Woodford. Probably just a pile of bones down there. I'd lock it, especially at night! :ahhh:
  10. oldgrezmonke New Member
    Finger TN
    The owner is deceased .
  11. kenny chaos Minister of Fire
    Rochester,ny
    Well you sure got me curious. Any vent pipes could have been knocked over, rusted out, or who knows what. Maybe it was the old guys money vault! Maybe an escape tunnel from the hospital or jail next door. A mine would be cool to.
    I'd be in there in a heart beat!
    My guess, a well.
    good luck on your property search-ken
  12. sleepie New Member
    elmira, new york
    if the rock come back out ----RUN!!!!
  13. Jay H New Member
    NJ
    If it is a bomb shelter, you might hit somebody on the head. owwwwwwwww!!!
    Jay
  14. oldgrezmonke New Member
    Finger TN
    Nearest hospital 35 miles , nearest jail 25 miles , little or no mining in this area . There are two visible wells-one with an old above ground pump in a well house and the other is a very old dug well , complete with rope , pulley and bucket , accessible from an enclosed porch . If it was a vault there must not be anything in it as it is held closed with a very old tire and a rock . Maybe I should look for holes in the ground that could be vent pipes . Or maybe I'll find Jimmy Hoffa .
    And if the rock comes back out-I will be the NEW world's fastest man .
  15. Jay H New Member
    NJ
    Nah, he's still buried under Giant Statium in NJ...
    Jay
  16. DAKSY Super Moderator
    Take a look at a town or county tax map, or the property survey.
    Whatever that feature is, it oughta be on there...
  17. Highbeam Minister of Fire
    If a good flashlight cant' see the bottom then it is a well. If it has valves it is gas. If you can see the bottom and it has no smell then it is likely a cistern, if the tank stinks then it could be an abandoned septic tank. Very unlikely to be any sort of structure intended for human entry like shelter.
    Any tank can be safely abandoned with a truck of sand or smashed in and backfilled. So while it is fun to guess the tank, it doesn't matter. That is, unless it smells of petroleum.
  18. oldgrezmonke New Member
    Finger TN
    Records like that are skimpy around here , especially on old properties .
  19. jdemaris New Member
    Central New York State
    Very common in my area of New York. It can be an old cess pool that got a new cement cover with access door installed, or a later septic tank with the same sort of access door. Top is usually buried a foot or so below ground - so you have to stick an extension of some sort that comes above ground. This way, if the tank needs to be pumped mid winter, you can get to the access door without digging through frozen ground. Just helps a guy set one up last month with an old cess pool that was originally covered with rail-road ties. I installed a HD concrete lid with 24" access door with two feet of culvert pipe to come out of the ground. Homemade extensions can be anything and old culvert pipe stuck on end is popluar. New septic tanks can be bought with factory made extensions.
  20. oldgrezmonke New Member
    Finger TN
    The sand idea might be useful since I'm worried about it collapsing sometime in the future . I never thought of a fuel tank , could be as this was part of a farm once . I guess I really need to get that real estate agent to see what he can find out . If that thing is too much of a headache I either might forget this place or really lowball the offering price .
  21. billb3 Minister of Fire
    SE Mass
    Could be a (semi-) artesian well. Room for a pump head.
    My well is 10 fet deep bt 10 feet by 10 feet wide. Room for a hundred gallontank and pump.
    Could be a lift pump for sewer, too if the sewer is above you up the street.
    Should be a plot plan record if the property has been sold recently.
  22. kenny chaos Minister of Fire
    Rochester,ny
    If it is a fuel tank, you could spend zillions and have to deal with the EPA. Dunno.
  23. Jags Super Moderator
    Northern Illinois
    Ken - get it right....its Ka-zillions.
  24. semipro Minister of Fire
    SW Virginia
    Many states have funds to help pay for this sort of thing. In VA, the cost to the landowner is limited to a max of $500 and most pay nothing. I worked in the environmental field for 10 years and ran across these sorts of things all the times during Environmental Site Assessments.
    Curious that its locked. That would imply its valuable or possibly dangerous to me. I'd guess its a cistern, well, shelter, or some such. Seems too big for a propane tank access.
    Hurry up and bust that thing open, I'm dying to know what it is!
  25. oldgrezmonke New Member
    Finger TN
    I have contacted the real estate agent to see if he can contact close relatives who might have knowledge of the place or find some record that includes this thing . Of course , I had already asked what it might be and the agent had no idea . I do not want to simply yank it open . I want to be sure of due care before opening the object , with a witness , that I had no intent of damaging anything that was not already damaged . I will let you all know what I find out .
Thread Status:
