    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. ckphoto New Member
    nj
    I just got the Breckwell SP2000I and installed it yesterday I have a few questions if anyone here is familiar with this model. First when I open the door it drops about 1 1/2 in. and I need to push up and in rather hard when closing the door, is this normal and if not is there a way to adjust the door. One of my other problems more of a complaint then a question is the hooper from what i read it should hold 70 lbs I have trouble getting 40 lbs in there. Also When it feeds pellets some times they miss and it always throws ambers is this normal.
    #1
    Helpful Sponsor Ads!
  2. hearthtools Super Moderator
    First I have not sold an Breckwell in years but have and still work on a lot of them.
    If this is an insert I think the top of the hopper is Adjustable (up or down) to fit the Hight of your fireplace. You will need to push the pellets back in the hole of an insert to get the max amount.
    I have never liked the Bay windows of the breckwells they have always sagged down and have had to pull the door up to close.
    Did you look and feel a stove in the showroom before you bought it?
    Sparks from the Sawdust burning is normal but if you have Pellets popping out then you need to adjust the air less.
  3. ckphoto New Member
    nj
    It is a insert I will look to see if there is some sort of adjustment but I do not think there is. I adjusted the air and haven't noticed any more pellets popping out.
  4. pegdot New Member
    Upstate, SC
    The Breckwell insert I have is old, 91', so this may not apply to yours but the door is a simple pin type hinge. No possible way to adjust anything on it other than the tightness of the latch. My door doesn't sag. What kind of hinge is on yours?
    Peggy
  5. pegdot New Member
    Upstate, SC
    The Breckwell insert I have is old, 91', so this may not apply to yours but the door is a simple pin type hinge. No possible way to adjust anything on it other than the tightness of the latch. My door doesn't sag. What kind of hinge is on yours? 1 1/2" is a lot of sag!
    Peggy
  6. hearthtools Super Moderator
    Peg
    the p2000 is a wide Sheet steel with 3 pieces of glass bay window unit
    not a solid cast door frame with glass like you have.
Thread Status:
