Buck 28000 blower question
Jonny006 Posted By Jonny006, Aug 10, 2013 at 10:39 PM
Thread Status:
  1. Jonny006
    Jonny006
    New Member 2.
    NULL
    Aug 2, 2013
    98
    6
    Loc:
    Ct
    I have been searching for the answer but to no avail so here goes-
    How does the blower work on these stoves? I know they are thermostatically controlled but how do I know it is working? The stove has a single toggle switch on the lower right front. It is a single position ie; on and off. When I plug it in and turn it on the blower turns on. I read that there is a three speed setup but how does that work? I'll I have to fire it up and see what happens? I was under the impression that the motor turns on when the stove reaches operating temp to move the hot air and cool the stove correct? Can someone set me straight here please.
    Thank you!
  2. central_scrutinizer
    central_scrutinizer
    Member 2.
    NULL
    Nov 12, 2008
    86
    1
    Loc:
    Greenwood, South Carolina
    Originally, the three-speed Buck Stoves were set up with a bar-type (CPI) thermostat and a two position switch (manual and automatic).
    If you plug the stove in and flip the switch to where the motor runs, this is the "manual" position. The fan motor will run regardless of stove temperature in this position.
    If you flip the switch to the opposite position, it will be on "automatic" operation. In this position, the fan motor will only come on when the stove reaches a certain temperature, and will cycle from low to medium, to high speed as the temperature of the stove increases. Of course, this is assuming that the thermostat is working properly.
    I hope this helps.
  3. gzecc
    gzecc
    Minister of Fire 2.
    NULL
    Sep 24, 2008
    4,416
    858
    Loc:
    NNJ
    I have a 28 also. Mine always had a two switch position. Automatic is up and manual (high) is down. Automatic is thermostatically controlled, manual control is high only (down position). Speak to the techs at servicesales above. They know it all.
  4. Jonny006
    Jonny006
    New Member 2.
    NULL
    Aug 2, 2013
    98
    6
    Loc:
    Ct
    Excellent. That was the info I was looking for. Thank you!
    And Servicesales has been a huge help with my questions. They will be getting my business.
Thread Status:
