Burning rotten wood?
tickbitty Posted By tickbitty, Sep 13, 2010 at 5:26 PM
Thread Status:
  1. tickbitty
    tickbitty
    Minister of Fire 2.
    NULL
    Feb 21, 2008
    1,551
    11
    Loc:
    VA
    If you have some wood that's good and dry but is punky or has some rot, do you burn it anyway? Someone told me they never burn anything with even partial rot. They have a cat stove, so I wonder if that's why? I just got a load of sorta rotty wood. There's some good stuff in there but it will take some sorting. But I just figured the rotted stuff would just burn right up, just faster. But maybe that's bad?
    I just don't want to hurt the stove, or anything like that!
  2. fossil
    fossil
    Accidental Moderator 2.
    NULL
    Staff Member
    Sep 30, 2007
    10,550
    2,421
    Loc:
    Bend, OR
    Don't have a cat stove, so can't address that aspect...but I'll burn partially punky splits in my stoves. If it's really punky through and through, I toss it in my dump trailer for the next run to the yardwaste recycle facility. (Don't have an outside fire pit). If I'm splitting and I've got some stuff that's punky on one side but otherwise solid, I'll split off the punk best I can & toss it, keep the rest for the stack. Not because I think it'll do anything bad to my stoves, rather simply because it's of marginal heating value. Rick
  3. Beowulf
    Beowulf
    New Member 2.
    NULL
    Dec 24, 2009
    211
    1
    Loc:
    SoCal Southern Sierras
    About the same process that fossil mentions above... I burn it in a non-cat stove, but can't picture why a cat would matter. Don't like the mess is the main reason I keep as much out as possible.
  4. firefighterjake
    firefighterjake
    Minister of Fire 2.
    NULL
    Jul 22, 2008
    17,635
    3,898
    Loc:
    Unity/Bangor, Maine
    Not much to add here . . . non cat stove . . . but I specifically toss my punky wood into my punk, chunk and ugly pile . . . this wood usually gets burned in the Fall of the year . . . or I pull from it when I need wood for camping or the fire pit. I will occasionally whack off some punk while splitting . . . but unless it's a sopping wet, falling-apart mess (i.e. fertilizer) I just keep the wood and burn it once dry.
  5. eernest4
    eernest4
    New Member 2.
    NULL
    Oct 22, 2007
    603
    0
    Loc:
    ct
    some rotten wood really smokes and stinks when you burn it. If neighbors or smoke police
    are a consideration, you may not want to burn some of the rotten wood.
    I try not to burn rotten wood because of the smoke and or stench it can create and out of a desire
    not to have my neighbors call the fire dept on me...
  6. branchburner
    branchburner
    Minister of Fire 2.
    NULL
    Sep 27, 2008
    2,684
    336
    Loc:
    southern NH
    Same here, but I find I'm keeping more punk than I used to because it burns just fine when fully dry, and is good for short pre-season fires (like today).
  7. Highbeam
    Highbeam
    Minister of Fire 2.
    NULL
    Dec 28, 2006
    12,325
    2,080
    Loc:
    Cascade Foothills, WA
    I don't like to waste wood. If it is stackable and solid enough to be split I usually put it in the stacks with the other firewood. It burns just fine. If it splits funny and is crumbly then it goes to the campfire pile which easily hits half a cord per 5 cords of stacked wood. This campfire pile is always burned up in our annual pumpkin carving party to occur this year the weekend before halloween! This fire can be substantial.
    Just remember, 8500 btus per lb. Nomatter how solid it is.
  8. cmonSTART
    cmonSTART
    Minister of Fire 2.
    NULL
    Nov 29, 2007
    2,284
    6
    Loc:
    Antrim, NH
    Personally I've never had a good experience burning punky wood. I usually just save it for campfires.
  9. Got Wood
    Got Wood
    Minister of Fire 2.
    NULL
    Oct 22, 2008
    927
    120
    Loc:
    Dutchess Cty, NY
    +2 ..... I have found though that punky wood does absorb moisture (rain water) so it needs to be kept covered in order to stay dry.
  10. xman23
    xman23
    Minister of Fire 2.
    NULL
    Oct 7, 2008
    1,429
    251
    Loc:
    Lackawaxen PA
    I used to save all the marginal wood for the fire pit. What I learned is all dry wood burns. In fact nothing goes up as fast as a dry piece of punkey wood. The only issue is getting it dried and keeping it dry. It's basically a sponge. So I still keep all the punk wood in a separate covered pile. I use it in the shoulder season, when we do quick small loads to take the chill off.
    Tom
  11. BrotherBart
    BrotherBart
    NULL
    Staff Member
    Nov 18, 2005
    32,824
    9,888
    Loc:
    Northern Virginia
    Since I do our grilling over an oak fire I use the punk wood to get the grill fire going good.
  12. woodjack
    woodjack
    Minister of Fire 2.
    NULL
    Jan 10, 2008
    502
    1
    Loc:
    Woodstock, NY
    Same here. As long as it's dry I've had no problems burning punky wood. I use it in the spring and fall, and to help my fires get going in the winter.
  13. SolarAndWood
    SolarAndWood
    Minister of Fire 2.
    NULL
    Feb 3, 2008
    6,784
    63
    Loc:
    Syracuse NY
    If it snaps when it splits, it heats the house. If it peels or crumbles or has too many bugs, it goes in the pit.
Thread Status:
