    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Swedishchef Minister of Fire
    Quebec, Canada
    Hey guys
    I was wondering if, when burning sugar maple, you can have a white froth coming from the wood for a few minutes? I currently have some maple in the stove (just put it in) and it is hissing with a white foam coming out the edge. Possible???
    Andrew
    #1
    Helpful Sponsor Ads!
  2. gzecc Minister of Fire
    NNJ
    Sounds like its not seasoned. How long has it been split and stacked off the ground in single rows? Do you have a moisture meter?
  3. pen Super Moderator
    N.E. Penna
    If it's only had one year seasoning on that maple, it may need more. I've found hard maple doesn't dry as fast as ash or beech for me.
    pen
    HDRock and Scotty Overkill like this.
  4. Augie Member
    North Of Canada
    It isnt the wood species that is important but the conditions that it encounters during seasoning. Hell with the right conditions, +100F and 5% relative humidity even oak will season in a few months... but yes it sounds like you have wet wood
    Redlegs likes this.
  5. pen Super Moderator
    N.E. Penna
    Exactly. I'm just saying that the conditions that would generally give me reasonably dry ash or beech in about a year, often times aren't enough for the maple.
    pen
  6. westkywood Feeling the Heat
    Kentucky
    I would think Sugar Maple would take longer to season than any other Maple.
    Woody Stover and Scotty Overkill like this.
  7. Scotty Overkill firewood hoarder
    central PA
    Sugar maple (and most of the norway maple I cut) takes every bit of two years C/S/S to be prime....
    silver and red maple takes a year. And I've had small rounds of sugar maple that were several years cut and stacked (unsplit) that still foamed on the ends briefly when put in the stove. Further proof IMO that wood seasons much better when split....
    pen likes this.
  8. lukem Minister of Fire
    Indiana
    Any wood can get frothy if there's too much moisture. The froth is just air and moisture escaping from the wood.
    Try that wood again next year.
    Scotty Overkill likes this.
  9. rideau Minister of Fire
    southern ontario
    Sugar maple has such a nice colored flame.
    And when cut at this time of year, the stump attracts dozens of varieties of butterfly, which one can enjoy watching while they feed.
    PA. Woodsman likes this.
  10. Swedishchef Minister of Fire
    Quebec, Canada
    Hrm. Ah well, I guess some of my maple is not dry yet..even if it has been c/s/s for 3 years!?!?!? And the rounds were only 6 inches or so in diameter.
    I will check with a moisture meter this afternoon on the other pieces and let you know..they sounded and looked dry to me!
    Andrew
  11. Backwoods Savage Minister of Fire
    Michigan
    Not much need for the MM as you already know it is not dry enough Andrew. Maybe you could boil that sap and get a spoonful of syrup?! I hope you get through this heating season okay. You can always try making sure you have a large coal bed before adding the wood which will help a lot.
    Swedishchef and HDRock like this.
  12. ohlongarm Minister of Fire
    Northeastern Ohio
    Only if green,other than that sugar maple burns hotter than a scalded dog,good wood Very hot burning when dry.
  13. HDRock Minister of Fire
    Grand Blanc, Mi
    Hissing kinda wet, foaming and hissing real wet
  14. Swedishchef Minister of Fire
    Quebec, Canada
    Weird. Something must have happened to certain pieces. Obviously what hissed is wet. But I tested other pieces from the same pile and they were 19 percent on the inside.....and some were 28 percent. And yet they are from the same stack!
    Hmmm
  15. Swedishchef Minister of Fire
    Quebec, Canada
    Thanks Dennis, but I wil pass on trying to get some syrup this year from those splits. Lol.
    Mixed with the other wood after 10 minutes or so the hissing stops...I still have over a cord of mixed wood left and that should easily get me through the rest of winter. I only make one fire a day now....
    Andrew
  16. Backwoods Savage Minister of Fire
    Michigan
    That actually is not surprising Andrew. Shoot, occasionally we get a log or two that is high moisture. I remember burning some 7 year old white ash. The tree was dead when it was cut. Still, 7 years later we got a couple splits that sizzled in the fire!
  17. Swedishchef Minister of Fire
    Quebec, Canada
    Dennis: glad to see I am not the only one. Kind of weird but there's not much that can be done. perhaps my piles weren't high enough off the ground and the piece may have been sitting on ground, etc??? Or the water gremlins are injecting water into my dry wood again.....
    Andrew
    Backwoods Savage likes this.
  18. gyrfalcon Minister of Fire
    Champlain Valley, Vermont
    That's my experience, too. Seems odd because it's such a nice dense wood, but beech dries pretty fast.
  19. Backwoods Savage Minister of Fire
    Michigan
    Or coon pee?! ;lol
  20. gyrfalcon Minister of Fire
    ROTLMAO!!
  21. Swedishchef Minister of Fire
    Quebec, Canada
    Haha Dennis... No coon pee around here. But I plan on getting yellow birch instead from now on... As pen and falcon mentioned, it dries much faster...
  22. gyrfalcon Minister of Fire
    Don't think I mentioned it, but I would if I'd thought of it... Yeah, yellow birch is good stuff. It's less common around here than hard maple, obviously, but I'm always happy to have some. If you can get black birch, it's even better, higher BTU and also pretty quick to dry.
  23. Swedishchef Minister of Fire
    Quebec, Canada
    I split a couple of pieces of maple from the same pile and measured the MC. one was 30% and one was 20%. However, I think I found the reason. It seemed the 30% was starting to get punky on the inside. however the piece with 20% was not. Would that "punky factor" hold moisture in the wood for longer?
    ANdrew
  24. Applesister Feeling the Heat
    Andrew you might want to research a thing called "Baterial shake in trees". Its more common in conifers and Oaks but maybe sugar maples. Bacteria causes cell wall breakdown and excessive moisture retention. Basically the wood never dries.
  25. Swedishchef Minister of Fire
    Quebec, Canada
    Hrm. Thanks Apple. I have never heard of this...perhaps some of the trees I cut were infected with this...I find it odd that wood that has been c/s/s for almost 4 years can have moisture content of 30%.
    It seems that may have been my problem with some of my wood....perhaps it was from the same tree....
