Everything you need has been discussed at length. If you are too dumb/lazy to put it together yourself, don't blame me.j-takeman said:Some how I feel like a used ?????. Got what he wanted and he's out of here.
We want to see the end result when you get it. I can use it to compare with what I have been doing. The full equation wouldn't hurt for us loser's either.
BDPVT said:whitsett2014 said:BDPVT said:Whitsett,
It's clear then, that the heat transfer efficiency of pellet stoves is often less than 60%.
Bottom line? Pellet stove efficiency is only as good as the efficiency of its heat exchange system
BDPVT,
Hey, thanks for the post! I had a couple of questions raised as a result...
1) Are the EPA efficiency numbers available for the public?
2) Given this overall percentage, could you take the expected output (by measuring the flow rate and gathering the input data) and multiply it by the average efficiency to find the instantaneous output of the stove? Of course this number would be strictly theoretical... I will need something more concrete.
For question two would you use only the transfer efficiency, or the total average efficiency?
To answer your question, they need to be reasonably accurate. Maximum +- a couple thousand BTU's hopefully.. This goal seems to be slipping through my fingers rather quickly without thousands of dollars of equipment though.
Thanks,
Whitsett
Answer to question 1) Yes, if the stove is certified it should be listed on EPA website. Table will show heat output BTU/HR. You may also get this info from the manufacturer.
Answer to question 2) You should be able to back into this number, but you are correct, it is theoretical. I would use transfer efficiency or total BTU output if possible. Problem is most stoves use the EPA 78% Default Efficiency Rate so you don't know for sure how they really compare.
whitsett2014 said:Everything you need has been discussed at length. If you are too dumb/lazy to put it together yourself, don't blame me.j-takeman said:Some how I feel like a used ?????. Got what he wanted and he's out of here.
j-takeman said:whitsett2014 said:Everything you need has been discussed at length. If you are too dumb/lazy to put it together yourself, don't blame me.j-takeman said:Some how I feel like a used ?????. Got what he wanted and he's out of here.
Dumb and lazy? Ha! I wasn't the one who came asking the questions and got most of his answers for free even. :sick:
Countryboymo said:I just stumbled in to this thread and all I can say is ..... WOW.... whitsett2014 you are totally out of line. Keep in mind as you travel through life that no one cares what you know until they know that you care.
Delta-T said:whenever a math situation arises that I have no clue as to what I need to input....safest to use a single digit prime number.....7 is my favorite.....3 never hurts...whats the worst thing that could happen?
mkling said:But then again heat exchangers are heat exchangers, there can't be that much different between those in pellet appliances vs. those in oil appliances, the principles are the same. So 130k BTU per gallon of oil would really equate to 130k*0.4 or 52k BTU of heat output per gallon of oil, using the same exchanger efficiency. If this is true then the pellets have about 2.5x (close to my 3x guess) more BTUs of heat output per bag vs. gallon of oil.
